Old 05-07-2016, 07:42 PM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Starter sticking maybe
Hello everyone my Yaris started making an occasional noise when I turn the car on is more noticeable if I don't wait at least 5 seconds before turning the key it sounds like a grind of something any help would be appreciated it here's a link to the video I recorded https://youtu.be/sAB6AMRH4yA it's a 07 Yaris by the way hatchback
Ramon1691 is offline   Reply With Quote
Old 05-08-2016, 03:07 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I don't hear anything out of the ordinary in your video.
Old 05-08-2016, 02:35 PM   #3
Ramon1691
Ramon1691's Avatar
I don't know how to explain it it sounds like a screeching of some sort is not the belt because I just changed it or squealing it has to be something with the starter doesn't do it all the time once in a while
Old 05-08-2016, 02:40 PM   #4
Ramon1691
Ramon1691's Avatar
But then again has been doing it since I bought the car 6 months ago so maybe I shouldn't worry about it, but then again don't wanna damage the starter if it that
Old 05-09-2016, 10:10 AM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I didn't hear it in your video either, but I captured it on video and posted about it here:
http://www.yarisworld.com/forums/showthread.php?t=55661
I also found this post reporting the same sound:
http://www.yarisworld.com/forums/showthread.php?t=54877
I've had my car at both Toyota and a highly Yelp rated independent shop and neither were able to get to the bottom of it. Part of the problem for me was that they said they couldn't replicate the sound.
I've found that it only happens earlier in the day when the car is colder, or on the first start of the day when the car is cold. Doesn't happen after the car has been started and ran for a while. The best guess from folks here has been the starter sticking too long after the engine turns over, and when pressed for an off the record guess, my mechanic thought the same. I've been holding off on spending the few hundred bucks it'll cost to repair as I'm afraid it won't solve it. Actually hoping the car starts to do it more often so my mechanic can hear it to confirm a diagnosis rather than replace something on guess work.
Please keep us updated if you end up getting to the bottom of it and I'll do the same in my post.
Old 05-09-2016, 12:25 PM   #6
Ramon1691
Ramon1691's Avatar
I will post an update as soon as I figure it out like I said it had done it since I bought the car ern -diz I will be going to my mechanic tomorrow but I think he is going to say everything is fine but I'll keep you updated so far starts every time with no problem just that sound interminent
Old 05-09-2016, 12:28 PM   #7
Ramon1691
Ramon1691's Avatar
I heard your video yours is very loud mine is not that loud you can bearly hear it on mine but you have to have the volume all the way up you're sounds like the gear of the starter grinding of some sort I'm not very mechanical inclined but that sound similar happened to a Honda before and I replaced the starter and it went away but then what do I know lol you don't want to go trowing parts at it because that could be expensive
Old 05-09-2016, 02:17 PM   #8
Ramon1691
Ramon1691's Avatar
I found this video in one of the forums it might help you this is the sound my car does when I start it up fast lol I always wait like 6 seconds before turning the key https://youtu.be/HRrVMtyIqIY
Old 05-09-2016, 03:09 PM   #9
ern-diz
ern-diz's Avatar
Okay, yeah, we have totally diff issues. Early on you used the terms grind and screech. What you really have is a squeal, which is almost definitely a belt. Mine and the one detailed in the other post is more of a grinding screech.
The fact that it doesn't happen when you start the car slowly is mind blowing. The explanation the guy offered in the last video you posted seams reasonable.
Starting issue birdman DIY / Maintenance / Service 10 11-28-2018 05:25 PM
Starter sticking or ??? CueBall DIY / Maintenance / Service 4 09-07-2014 01:52 AM
Remote starter recommendation and questions GrayYaris DIY / Maintenance / Service 3 05-30-2014 01:06 PM
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
