#1 |
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Hi all,
I sometimes get the ABS light come on my dash. I checked with diagnostic scanner and I get the following error codes: C1241, C1249 As this is an intermittent issue that only occasionally shows up, could it be an issue with the battery or alternator ? I have already cleaned the contacts on the ABS ECU connectors. I am reluctant to take the car to the dealer to have this checked. I had a battery health test done and I am told that my battery is OK but may need replacing soon as its now reading 275CCA and it is a 330CCA battery. I have no idea when the battery was last replaced, owned the car for 2.5 years now with the same battery, I suspect the battery is still the same from when it came from Japan which is about 3 years ago. |
| Tags |
| abs, alternator, battery |
| yaris abs brake light speedometer and electric powersteering issues | dave van muyden | DIY / Maintenance / Service | 4 | 10-26-2013 02:33 PM |
| FRONT ABS | htschek | DIY / Maintenance / Service | 1 | 08-05-2013 09:14 PM |
| ABS brakes / Would you buy a Yaris without them? | 3cyltrbo | General Yaris / Vitz Discussion | 66 | 03-26-2011 08:21 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
