Old 05-12-2016, 05:47 PM   #1
willisjm193
Yoshi 2.0
willisjm193's Avatar
Drives: 2007 Manual Sedan
Battery light / no cruise
The title pretty much states my issue. I've searched the forum and didn't really see anything to help. My battery light does not extinguish after I start my car - no flashing. The only issue I've noticed since this light came on is that my cruise control stopped working. The car starts fine, and the alternator seems to be charging the battery. Any guidance would be appreciated.
Update: ALT-S fuse is blown, new fuse blew as soon as I inserted it
willisjm193 is offline   Reply With Quote
Old 05-12-2016, 08:09 PM   #2
The ALT-S fuse feeds battery power back to the alternator. If it is blowing there is an issue with the voltage regulator within the alternator. There is a known issue with them corroding on 07 Yaris.
Old 05-12-2016, 08:58 PM   #3
willisjm193
Yoshi 2.0
I read a few posts where you said that before, so I took it apart to look at it. It was pretty clean. Would that cause the alt to fail if I took the alternator in to get tested? Also, is it safe to drive until I can get another?
Old 05-12-2016, 10:16 PM   #4
If the regulator fails, it can cause no output from the alternator, or the complete opposite and way over charge the system.
Old 05-13-2016, 09:18 AM   #5
mik23
Drives: yaris 2005
Hi
Have you got the diagram from manual that could be the starting point to check.
mik23 is offline   Reply With Quote
2007 Yaris S alternator overcharged battery, replaced both now no P/S Ala2014 DIY / Maintenance / Service 2 12-31-2014 06:16 PM
Steering Wheel Jams, Battery Warning Light flickers, Starting Issues tmrtza In Car Entertainment + Electronics (audio / video / alarm) 3 10-31-2014 09:01 PM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
Light weight race battery. buddyjim Performance Modifications 24 01-27-2009 08:33 PM
