Old 05-19-2016, 06:34 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Oil analysis results
Here is my 2zr's first oil analysis results. Aside from some additives and minor contamination(probably from the time this engine sat in the junk yard) it's a clean bill of health!
Old 05-19-2016, 08:55 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Very nice!
brushforhire is offline   Reply With Quote
Old 05-19-2016, 10:02 PM   #3
thanks for the post!
Old 05-20-2016, 01:45 AM   #4
ArmstrongRacing
Data doesn't lie
These tests are the best way to monitor your car, $30 test and it gives you so much piece of mind
Old 05-20-2016, 09:01 AM   #5
bronsin
bronsin's Avatar
Five quarts of oil?
What else have they got wrong?
Old 05-20-2016, 09:45 AM   #6
brushforhire
Honestly, the true dry to fill capacity might be closer to 5 qts, and I'm sure the 2zr could hold 5 without issue, so it really isn't that wrong. It holds 4.5 according to a drain and drill as per Toyota.
Old 05-20-2016, 10:44 AM   #7
bronsin
bronsin's Avatar
The 5 qts in the sump refers to the Yaris in the oil analysis.
Old 05-20-2016, 11:20 AM   #8
brushforhire
Yes, but his Yaris has the 2zrfe in it. Maybe I'm not fully understanding this analysis. I was under the assumption, they pulled the oil from his vehicle and checked it, so he should of had at least 4.5 qts in it.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
Old 05-20-2016, 11:29 AM   #9
bronsin
bronsin's Avatar
Wow!
Old 05-20-2016, 01:53 PM   #10
ArmstrongRacing
Data doesn't lie
These oil analysis check only 5-6oz of your oil, they need to know your sump amount to calculate your percentages. The 2zrfe is 5qts dry.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
