Old 05-24-2016, 07:58 PM   #1
oij040173
Drives: Toyota Vitz 1999
Yaris 2005 codes P0722 and P2767
Hi friends,
I got codes P0722 and P2767 on my yaris.
Anyone know how to troubleshoot these codes?
Where are these sensors locared?
thanks
oij040173 is offline   Reply With Quote
Old 05-24-2016, 09:30 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Should both be the same sensor. The speed sensor on the transmission. On mine it is on top of the trans toward the back. It had three wires going to it.
I have a 2007 yaris, auto.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 05-28-2016, 12:22 AM   #3
B.B._07
Drives: 07 5dr
Looking up the codes I found:
P0722 Output Speed Sensor Circuit No Signal
P2767 TOYOTA - Input/Turbine Speed Sensor 'B' Circuit No Signal
So looks like the speed sensor is getting no signal in or out. The three wires should be 12 power, a pulse waveform output, and a ground wire. I would check the connector to the speed sensor for a loose connection or corrosion. You can check 12 power wire and ground wire quite easily with a test light or a multimeter
