Old 05-26-2016, 09:44 PM   #1
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Sump Guard / Splash Guard retention
Hi All,
I had the last remaining clips holding the guard under the engine to the front bumper fall out while travelling at 100 km/h. The Yaris was due for a service soon, so I used cable ties to reattach it until I went to the dealer's.
The service rep from the dealer (yes, actual Toyota dealer) said this is a known problem with the Yaris - the retaining clips are flimsy and it only takes a light scrape on a driveway or similar to make them fall out.
He then went on to say they replace any missing clips with CABLE TIES as these are more secure, and avoid any more problems...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 05-27-2016, 05:01 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
I wonder if it depends on the country in which the Yaris is sold or Toyota have decided the guards are not secure enough or they want to save some money?
My 2014 Yaris does not have an under engine cover. The result of this is that, in winter, the salt spray from the roads covers the front of the engine and some parts of the engine bay.
mrpj is offline   Reply With Quote
Old 05-27-2016, 09:38 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It's possibly dependent on coutry of manufacture, amongst other things.
My 2012 built Yaris was assembled in Japan and has the 2NZ-FE 1.3 litre engine With 4 speed automatic transmission.
Old 05-28-2016, 05:43 AM   #4
mrpj
You are probably correct Kevin. U.K. spec. model, so French built.
I'd prefer for there to be a cover whether secured by cable ties or not! My previous Mk. 2 Diesel Yaris (French) had one with a suitable hole directly under the oil drain and a hatch for access to the engine oil filter.
Old 05-28-2016, 07:25 AM   #5
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
https://www.sump-guard.co.uk/steel-s...aris-2011-2015
Gagi is offline   Reply With Quote
Old 01-06-2017, 11:43 AM   #6
cherrmj
Drives: 2010 2Dr
Hello all, My daughter has a 2010 2Dr Hatchback. Both front sides need Wheel well splash gaurds. A couple of questions please.... When ordering online how do you increase your chances of getting the correct fit and what site? Any links or instructions to install? Both sides are currently missing. Thanks Much!!!
cherrmj is offline   Reply With Quote
SPLASH GUARD anahtar DIY / Maintenance / Service 2 12-21-2016 12:01 PM
WTB Engine splash guard + wheel well liner (for 07 Sedan) LeetViet Willing to Buy by private party 0 07-03-2014 01:26 PM
Splash Guard GeneralDon7 DIY / Maintenance / Service 0 03-06-2009 11:30 PM
