Old 05-28-2016, 11:39 PM   #1
costica
Drives: yarius III
toyota yaris 2013 key blade
What type of blade is required to copy a toyota yaris 2013 key? I tried to copy key with a toy47 blade bought on eBay but this copy work only for the driver door but don't works for the contact. I assume that the blade used does not match.
costica is offline   Reply With Quote
Old 05-29-2016, 12:33 AM   #2
Biginjapan13
Drives: lowered/ exhaust
If your car has an immobilizer then you have to get it programmed by toyota
Biginjapan13 is offline   Reply With Quote
Old 05-29-2016, 12:46 AM   #3
costica
Drives: yarius III
You don't understand. I can't rotate the copied key in the ignition switch. Copied key works only in the driver door. The original Toyota key work fine in ingnition switch and driver door.
Old 05-29-2016, 12:48 AM   #4
costica
Drives: yarius III
Does anyone know what type of blank blade are used for Yaris 2.
Old 05-29-2016, 12:48 AM   #5
Biginjapan13
Hold both keys together and see if their cut the same or juggle the key in the ignition cylinder. Sometimes if a key is cut just slightly differently it will work in one thing and not another
Old 05-30-2016, 10:24 PM   #6
B.B._07
Drives: 07 5dr
The issue you're having is that the key is not cut well enough so it will work on one lock but not on all locks in the car. You need to take it back to where you got it cut to see if it's possible to get it fixed. It's a common issue with poorly cut keys or keys duplicated from well worn keys. When I bought my 07 it only came with one really worn key that I tried to have copied which resulted in a key that only worked in the ignition on one side and in none of the other locks.
Also in a 2013 Yaris you will need a key with an immobilizer chip that needs to be programmed otherwise even if the key turns in the ignition it will not start the car. You don't have to go to a dealer but you're options for programming are a dealer, a professional locksmith, or somebody that has access to Techstream software (and the cable).
2013 Black Toyota Yaris LE - 51000 odo tyta4lfe Cars for Sale by private party 1 08-23-2016 10:41 PM
Toyota Yaris 2013 with Touch and Go intercar In Car Entertainment + Electronics (audio / video / alarm) 0 10-29-2015 07:51 AM
Recent Toyota Yaris recall " electric steering" marcus DIY / Maintenance / Service 6 07-10-2013 02:30 PM
