Old 06-09-2016, 01:43 AM   #1
SM-17
Drives: Toyota Vitz 2009
OBD II on Toyota Vitz 2009
Hi All,
I own a Toyota Vitz 2009 Japan import, 996cc 1KR-FE Engine, T410CVT and would like to know if it uses OBD II or a variant of OBD so that I can buy the OBDlink MX scanner to see ecu codes Etc.
The wired pins on the port are: Pin 4, 6, 7, 9, 12, 13, 14, 16
Thanks to all
SM-17 is offline   Reply With Quote
Old 06-09-2016, 04:26 PM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I don't know about the Vitz, but the Yaris uses pretty standard OBD II, and I've been able to use a regular OBD II Bluetooth dongle with no problems. I seriously doubt that the Japan version of the same car would be different at this level.
Sent from my LG-D801 using Tapatalk
Old 06-09-2016, 04:38 PM   #3
SM-17
Yaris and vitz have different electronics, the port active pins are different thus probably a different protocol
My cousin has a yaris uk import and obd port have different active pin layout.
Sent from my SM-N910C using Tapatalk
Old 06-09-2016, 07:33 PM   #4
Vitz is not OBDII. It is M-OBD.
Old 06-09-2016, 11:45 PM   #5
tarkus
tarkus's Avatar
I stand corrected. I also find that pretty strange.
Old 06-10-2016, 01:35 AM   #6
SM-17
@CTScott
So, to use obdlink MX (and torque app) do I need a different init. String and different pid's?
I think this is the init string required : ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100
Can you give me a hint about pid's please? cos i cannot find any
Thank you!
Old 06-10-2016, 05:38 AM   #7
Originally Posted by SM-17 View Post
@CTScott
Thank you!
M-ODB is a completely different protocol. I don't have any info on it.
Old 01-31-2017, 10:05 AM   #8
AGDS91
AGDS91's Avatar
Drives: VITZ RS 2005 NCP91
hola.
Que escaner es compatible con el vitz rs 2005?
Elm327 No Work.
Easy Diagnostic for launch x431 - Varias marcas de automoviles?¿
TachYon T100 BT - solo toyota?¿
AGDS91 is offline   Reply With Quote
Old 07-15-2017, 02:46 PM   #9
sceh
Drives: yaris 2004
Under no circumstances buy Tachyon. I had the Tachyon T1 and it never worked and there is ZERO support - they never reply to mails and you might just find someone on the forum. The Android application is a joke and NONE of the advertised functions work at all - like reading or clearing DTCs.
COn trick
sceh is offline   Reply With Quote
Toyota axes Scion Kar98 Off-topic / Other Cars / Everything else Discussions 15 02-10-2016 12:01 PM
2009 Toyota Vitz/Yaris 1.3L hatchback Engine Heating Up VitzBD DIY / Maintenance / Service 8 09-22-2015 07:01 PM
Toyota yaris hatchback headlight fits on Vitz 2005? urguardian Cosmetic Modifications (Exterior/Interior) 2 09-11-2014 04:46 PM
DIY, can i install HID which have High and low beam together in Vitz 2009? digitalprecinct Cosmetic Modifications (Exterior/Interior) 14 05-02-2014 05:47 PM
FS: JDM Vitz RS Front (2009) and Rear (2007) Bumper (AZ and Possibly So Cal) jmew0ng Items for Sale by private party 23 10-05-2013 12:24 AM
