Old 06-11-2016, 10:29 AM   #1
baseballfan416
Drives: 2017 L 3-door
Anyone ever have issues installing as brake lines?
Brake pedal is super mushy, decided to get a stainless steel brake line kit for the front lines... Only problem is it seems the connection from the hard line (10mm) to the hoses are cross threaded? You have to twist from the hose (17mm, that only has two sides and is rounded to fit a hanger) to avoid bending the hard line, but it seems I'm just rounding the 10mm screw on the hard line. Soaked the connection in pb blaster/creeper oil but nothing seems to help it budge.
Car has just over 143k miles.
Any suggestions? I'm thinking at this point I almost need to replace hard line but money is tight and I'd have to pay someone to do that.
baseballfan416 is offline   Reply With Quote
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
SS brake lines installed. UberSilver DIY / Maintenance / Service 6 02-26-2013 12:52 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Adjustable sway bar endlinks and steel braided brake lines installed Brian Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-15-2009 10:57 AM
