Old 06-14-2016, 11:45 AM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Better alternative to front bumper push pins/retainer clips for 2009 Hatch?
I've had the front off a few times due to light bulb changes and have managed to bust some of the pins... is there a sturdier alternative to these things? Like ones that expand with a Phillips head screw insert that will fit?
I've seen a few threads but no actual part numbers that are a direct fit and will work...
firebird1999us is offline   Reply With Quote
Old 06-14-2016, 12:50 PM   #2
Rigaud
Drives: 2009 Yaris
The OEM pins are expansion type. I have the original from 2009 and removed the front 5 times. Depends how you pulled them off?
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 11-11-2016, 08:13 AM   #3
firebird1999us
Drives: 2003 Mach 1
To follow up - I found some plastic expanding screw in ones that are easier to remove and seems a little sturdier than the Toyota ones. I ended going with these and couldn't be happier:
Old 11-11-2016, 12:30 PM   #4
Zip tie. I use zip ties where ever I can loop it, like the top bumper clips. Haha
Sent from my SM-G930W8 using Tapatalk
Old 11-11-2016, 05:13 PM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
+1 on the Zip ties.
When I had the clips come of the under tray, I temporarily zip tied it back up, as a service was nearly due. I asked the service rep to replace them, and he said the original clips get damaged and fall out very easily. Their policy was to replace any missing clips with zip ties.
Yes, this was at the Toyota dealership...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-11-2016, 05:26 PM   #6
So nobody feels like applauding the OP for sourcing out and posting up some proper reusable push pins. Not everyone feels like going ghetto with zip ties, even if they do function perfectly.
Old 11-11-2016, 07:59 PM   #7
ebaut
ebaut's Avatar
Drives: Yaris 09
Great tip. Ill order me some.
ebaut is offline   Reply With Quote
Old 11-12-2016, 04:39 PM   #8
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Looks good, I just found similar clips for sale here in Australia.
I sure hope they are cheaper for you in the US. My 'local" (15 kilometers away) car parts store has tem for $6.29 a pack. a "pack" is either three 1/4 inch clips or two 3/8 inch clips.
I guess it's time to crawl under the Yaris to see how many and what size I need.
Thanks to Firebird for finding these, and WeeYari for the reminder that we are all here to help each other.
Old 11-18-2016, 10:27 AM   #9
firebird1999us
Drives: 2003 Mach 1
Originally Posted by kevinj93 View Post
+1 on the Zip ties.
Yeah my front bumper has been totally replaced twice for cosmetic damage while driving. With an entirely new set of push pins every time and attempting to be careful during light replacements I was still having problems with them not reseating right or busting... I mean technically you could use a screw and a wing nut in at least a few places - but these seem super sturdy, well as sturdy as a plastic screw can be, and I won't have to cut them out every time for removal!
Old 11-18-2016, 09:51 PM   #10
SirDigby
Drives: 2007 yaris 3 door
I don't understand this thread. what's wrong with the factory ones?
Old 11-18-2016, 10:36 PM   #11
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
They break and fall out easily.
Hearing a loud clunk and scraping noise when they let go and the under tray hit the road surface wasn't the best thing to happen on the highway.
See my earlier comment. The Toyota dealer's service rep agreed there is a problem with the originals and stated they replace missing clips with cable ties...
Old 11-19-2016, 02:31 PM   #12
SirDigby
weird. I have threaded bolts on the bottom of my bumper. push clips are only on the top and the wheel well on mine. (07) I've never had any break or fall out. I do find it strange that the push clips on yaris are different than the ones on corolla/camry.
Old 10-17-2019, 11:08 PM   #13
cesturdy
Drives: 2007 toyota yaris sedan
The official toyota repair manual indicates the front bumper cover is held by 6 clips at the top, 2 screw grommets (one near each side), and at the bottom 7 screws and 3 bolts. This is for the sedan. There are also spec in the manual for the hartchback. Can anyone tell me the size and part # of each of these fasteners?
cesturdy is offline   Reply With Quote
Old 10-18-2019, 10:12 AM   #14
stykerdk
Yaris Hybrid Limited 2015
https://www.ebay.com/itm/50-Pcs-Blac...MAAOSwPNBdVlYR
https://www.ebay.co.uk/itm/100Pcs-Pu....c100008.m2219
C-HR 1,8 Hybrid premium 2020
Old 10-18-2019, 08:50 PM   #15
cesturdy
does not ship to u.s.
The two items you referred me to on ebay do not ship to the united states.
Old 10-19-2019, 01:24 PM   #16
Snappy
Drives: 2 Yaris Hatchbacks
I recently replaced my headlamps and needed new pins (old ones crumble.) I bought these Amazon ones and they fit and appeared like OEM for my 07 hatch.
https://www.amazon.com/Rexka-Bumper-.../dp/B07CKG4RG7
Snappy is offline   Reply With Quote
Old 10-21-2019, 12:55 PM   #17
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've had very mixed results with ordering the OEM part numbers off the diagrams. There are some very small ones with a textured head that barely fit and will fall out if the bumper cover holes are wallowed at all, barely engage the metal holes. I've got a few different styles at home that I've used with varying success. I'll try and remember to get a picture of them with part numbers.
Need a LH front and rear bumper retainer white_rice DIY / Maintenance / Service 1 04-16-2015 04:43 PM
WTB Used Yaris (2nd gen) original front bumper nicl Willing to Buy by private party 0 08-17-2014 01:43 PM
for sale - yaris hatch front bumper (slight damage) jesse1000 Canada 4 12-06-2008 09:03 AM
FS: JDM Modellist II Front bumper & JDM LED tails DKN-YARIS Items for Sale by private party 7 11-09-2008 01:10 AM
Thailand OEM/Aftermarket Accessories and Bodykits GB Round 2! eTiMaGo Items for Sale by private party 118 09-10-2007 02:10 PM
