Old 06-18-2016, 10:18 PM   #1
meemadd
Drives: 2009 yaris
i have a 2005 ECHO 4 dr auto and body roll question
ive looked at several suspension mods,im not trying to make a racecar out of it just want to know what the bare minimum is i need to do to get it handle better in corners and at highway speeds for it to not wander,maybe dropping it 2 inches or maybe better tires or sway bars or bushings?,not sure i want much wider tires maybe one or two sizes wider,i dont want to hurt its gas mileage, ty
meemadd is offline   Reply With Quote
Old 06-19-2016, 09:56 PM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I had a 2004 auto hatchback, which also suffered from body roll. Just changing the wheels for 15" rims with 195/55 R15 gave a significant improvement. You can't go much bigger than that in size with an automatic. Following that, the addition of a sway bar at the rear is also highly recommended, as is lowering the suspension a bit. Around 1.5 inches is quite safe and won't get you into wheel rubbing issues.
Sent from my LG-D801 using Tapatalk
Old 06-20-2016, 02:47 AM   #3
rabbito
rabbito's Avatar
i have 195/50/15 with sway bar, strut brace and dropped a little bit more than 2 inchs with performance spring and shocks..
just like Tarkus mentioned, 195 is the widest you can go...you should check out Hankook RS3 performance tires..i believe tires are important than any mods ive done..seriously... 😐
I should have upgraded to performance tires..i have semi performance Hankook V2 tires and i regret them...should have went for RS3s...😭
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 06-20-2016, 08:57 PM   #4
Eibach prokits
Old 07-11-2016, 05:18 PM   #5
Viperoni
Drives: 2005 Toyota Echo
205/50/15 will fit fine, and with the right wheel and fender rolling, so will a 225/45/15.
2006 Saturn Ion Redline
Old 07-15-2016, 03:56 PM   #6
tarkus
tarkus's Avatar
If it has automatic transmission, you have to stay within 3% of the stock outside wheel diameter. The tire size calculater on 1010tires.com is handy for working that out. You get a lot more leeway if it's a manual.
Reasonable Auto Body Shops in GTA? VTECMAN Canada 7 03-03-2012 02:46 AM
Auto Body Training course Free online Arkhangel DIY / Maintenance / Service 0 12-10-2009 08:18 AM
