Old 06-26-2016, 04:38 AM   #1
rabbito
rabbito's Avatar
Lightweight Pulley Complete
You can check out my TB and Spacer post i completed earlier, so you can check that post out after reading this..
now finished the lighweight pulley and drove 50km back home from the shop(far af..😧)..it does free up and gain hp/tq through out the power band, someone in the yarisworld claimed 2-3wrp after he got pulley installed, i think it makes sense...the rpm moves up a lot quicker, i mean a lot quicker...huge improvement..there isnt a lag between 2000-3000rpm anymore..i feel pulley isnt about hp gain, more of a faster rev..😮😮😮
i think doing all the small mods to your engine just adds up..😀😀😀
i will write up my whole completed stage 1 yaris sedan later..😊😊😊😊
feel free to ask me any questions
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 06-26-2016, 09:37 PM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Which pulley wheel did you use?
Sent from my LG-D801 using Tapatalk
Old 06-26-2016, 10:12 PM   #3
rabbito
rabbito's Avatar
SPR Performance..brand in asia
Old 09-17-2016, 10:47 AM   #4
danisnug
Drives: '16 NCP150R
Are those affect the air conditioner? A friend of mine claimed that it might reduce the performance of the a/c
'16 NCP150R
danisnug is offline   Reply With Quote
Old 09-17-2016, 10:52 AM   #5
rabbito
rabbito's Avatar
how??? 😮😮😮😮😮
so far no issues...rpm just goes up slightly faster and small hp gain...😎
Old 09-18-2016, 01:45 AM   #6
SirDigby
Drives: 2007 yaris 3 door
what is the weight difference? I've been looking for information on the weight of the stock pulley, but haven't come up with an answer.
can you weigh stock pulley?
thanks.
Old 09-18-2016, 07:18 AM   #7
thanks.
Stock I think is around 3.5lbs
Old 09-18-2016, 07:23 AM   #8
rabbito
rabbito's Avatar
thanks.
i just weighted them right now....1.5kg..about 3.4 pound...😑😑😑😑
when i lifted the current pulley that i have installed, it was like 50% lighter than stock...
Old 09-29-2016, 07:43 AM   #9
lupetnen
scph/jdmuph
Drives: toyota vios ncp42
sir sent you a pm interested with that product
lupetnen is offline   Reply With Quote
FS: Micro Image lightweight crank pulley malibuguy Items for Sale by private party 2 08-22-2015 08:30 AM
Micro Image crank pulley - prototype complete! cali yaris Micro Image 111 11-10-2014 10:24 AM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
Lightweight Crank Pulley axiom Performance Modifications 16 09-01-2014 09:29 PM
For Sale: NST Lightweight Pulley Set CTScott Items for Sale by private party 2 12-03-2013 01:18 PM
