Old 06-28-2016, 12:28 PM   #1
grayb
Drives: '07 Yaris Sedan
Questions about Yaris wheel fitment
I have a US 2007 Yaris sedan. I'm still on the original wheels and they've had a very rough life. The ride is suffering for it and I'm looking for a new set of wheels and tires while trying to be frugal and DIY. I'll get the tires at a local shop, but looking for wheels online.
I found these on ebay, and the specs look right for my car. I already have the stock 15" steel wheels, so these should be about the same:
http://www.ebay.com/itm/331774482870
Then going on that wheel's specs of hub bore at 72mm, and another post I found here that listed the Yaris hub bore at 54.1mm, I would need these hub rings:
http://www.ebay.com/itm/361355856077
Please let me know if I've missed anything, or if I am doing this wrong. This is my first time buying wheels. Thanks.
grayb is offline   Reply With Quote
Old 07-07-2016, 10:06 AM   #2
3cyltrbo
Personally I've never seen a hubcentric ring used on a steel wheel? (do they have enough of a mounting flange to accommodate the hubcentric ring?)
I see that those steelies are pretty cheap ($160 ish), have you looked around for inexpensive alloys or even something used (maybe even a local scrapyard)
Will
3cyltrbo is offline   Reply With Quote
Old 07-07-2016, 10:17 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Are your original steel wheels damaged? If not, then why would you want to replace them with after market steel wheels?
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-09-2025 11:20 PM
Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise DevilzMafia DIY / Maintenance / Service 8 12-24-2012 08:05 AM
Winter Tires and wheel for my 2012 Yaris SE etherdude Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2012 11:52 PM
