Old 06-28-2016, 08:21 PM   #1
mekman
Drives: 2008 Yaris
2008 Yaris Horn Issues
Hello - my horn on my 2008 Yaris hasn't been working for the past month or so. At one point a few months ago, the horn would randomly go off and I'd have to hit/jolt it to make it stop. Now, the horn isn't working at all.
I checked the fuse, and it was blown, so I replaced it with the spare. The spare didn't work either - so I removed it, and saw that now the spare fuse was also blown. I replaced it again with another good fuse, tested the horn (no luck), and then noticed the third fuse had now also blown.
The fuse does not blow until I hit the horn. Any ideas on what may be causing this? I've read some suggestions, and I keep seeing the horn relay mentioned, but I haven't been able to find any good information on where the horn relay would be for this. I read it's supposed to be right under the horn fuse, but there doesn't seem to be a relay there.
I've attached a pic of the fuse box. The horn fuse is the slot at the top with no fuse attached.
Any help is much appreciated.
mekman is offline   Reply With Quote
Issues with recharging 2008 Toyota Yaris ItsanEE DIY / Maintenance / Service 4 11-21-2014 02:21 PM
Should I buy a Toyota Yaris Sedan (2008)? cassiebrighton New YARIS Purchase Forum 2 09-12-2014 06:44 PM
A few OEM 2008 Toyota Yaris parts white_rice Canada 0 03-20-2010 05:23 PM
