Old 07-09-2016, 12:53 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Can a TC fit in a Yaris
Just a thought i had. Now that i have seen some Scion Tc with rear end damage going for 1500-2000 that run and have a MT. might be an idea to ponder by swapping the 2.5L and 6 speed int a yaris and see how easily the increase would make for quite the fun upgrade. plus the larger aftermarket parts distribution.
Just a thought it had, wondered if anyone else had had it too?
Old 07-09-2016, 01:21 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm pretty sure it's too wide. The 2ZR and 2AZ are both available in the Matrix/Corolla, but that's a much wider engine bay. That said, don't let me stop you from trying it. ;)
Old 07-09-2016, 06:26 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
2GR fits
Old 07-10-2016, 03:56 PM   #4
Golddeenoh
Golddeenoh's Avatar
nothing a little cutting ans welding cant fix. might have to make the front clip out of tubing to make the swap possible. maybe even take the whole harness and modify it to fit in the yaris.
Old 07-14-2016, 10:50 PM   #5
Do IT!
Old 07-14-2016, 11:30 PM   #6
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Doesn't the TC have the same 2.4L that came in the Camry and Solara?
Black_griffin6 is offline   Reply With Quote
Old 07-15-2016, 02:13 AM   #7
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
^ yes.
Old 07-15-2016, 10:39 PM   #8
Golddeenoh
Golddeenoh's Avatar
yes and it is easier to find a manual transmission in the TC version, the Camry did come with them as an option but not a common one.
Old 07-21-2016, 06:13 PM   #9
Kar98
Drives: 2011 Scion tC
Question is, why would you want to do that? The tC is a much better car than the Yaris. Just swap your own ass over from a Yaris to a tC and be done with it!
Old 07-22-2016, 09:06 AM   #10
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I thought the trend nowadays is to just LS V8 swap anything and everything. ...so why even bother with a tC.
Old 07-23-2016, 05:16 PM   #11
Golddeenoh
Golddeenoh's Avatar
sleeper status more than anything.
The Ls4 is a candidate, but seems hard to find a complete one.
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Base Honda Fit only $800 more than base Yaris. Why is that? matti General Yaris / Vitz Discussion 37 03-28-2015 08:31 AM
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 05:35 PM
