Old 05-15-2007, 03:37 AM   #1
spkrman
Drives: 1
Turbo auto yaris top speed and 0-60
From 8 to 117 (125 with the speedo offset of the 20's). Had to pause for a sec for bumps/on ramp turns. Didn't feel like traveling for a stretch of smooth highway.
Turbo def made a BIG difference here... before it wouldnt get past 105, and this is after almost 2 miles lol. It hit top speed before it would have otherwise gotten to 100.
Compare to shinlee's stock 5 speed top speed run:
http://vids.myspace.com/index.cfm?fu...oid=2029109187
The 0-60 vid, tough to say exactly where "60" is with the dubs on, but this vid was made slightly uphill.
Old 05-15-2007, 03:58 AM   #2
sweet! heh, didn't know it beeps when you hit the limiter.
Old 05-15-2007, 04:02 AM   #3
spkrman
Drives: 1
That was actually my radar detector, and then blowoff valve :)
When you hit the governer, you def know it... the car basically takes the throttle off, even though your still flooring it. I assumed I had found the top speed before, but that was just the car running out of power lol This was definitely the governer... and I'd say the top speed has yet to be defined, I bet it could hit whatever the tranny limits it to as it was just getting back into the peak power band.
~125 was pretty fun, it wasn't really unstable... but it definitely didn't feel planted all the way up there.
Old 05-15-2007, 04:26 AM   #4
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
So the automatic tops at 125, but do we know what the 5spd tops at with Turbo?
TurboYaris?
Or at least do we know what an Xa Turbo tops at with 5spd.
Old 05-15-2007, 06:01 AM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@spkrman: Very nice!
Old 05-15-2007, 01:46 PM   #6
spkrman
Drives: 1
TurboYaris?
The rims throw off the speedometer, 117 on the speedo is actually 125.
Old 05-15-2007, 02:18 PM   #7
hahaha, i thought it was a chime, like what they have in Japan (at least from Initial D )
Old 05-15-2007, 02:23 PM   #8
ChinoCharles
Drives: LB
Dude, the dubs need to go! Put them in the garage for shows and grab some real rims so you don't pit your chrome tearing your new turbo to bits. I'll bet you're carrying damn near 37 MPH into second. Still doesn't make it a Ferrari killer, but its bearably fast now.
Old 05-15-2007, 02:29 PM   #9
spkrman
Drives: 1
lol
The end of 2nd is right around 70mph. Manually shifting out of first used to make quite a difference 0-60, it goes too fast now to time it out perfectly everytime though... it doesn't exactly shift exactly when i throw it to 2... 1st can be held to almost 40mph... pretty crazy... this is why I want to try a set of shorter tires.
I'll grab a set of 15's soon, along with the lightweight crank pulley... and, well, not alot more that can be done until some tranny work is performed.
I may look into a boost controller, I think up to maybe 9 psi would be safe if not used constantly... more than anything I'm curious as to how it would perform.
Old 05-15-2007, 03:27 PM   #10
FlyingDevil
FlyingDevil's Avatar
Drives: 07 Corolla
i know its off topic, but will ur car pass emissions? (i ask because the turbo eliminates one of the o2 sensor)
FlyingDevil is offline   Reply With Quote
Old 05-15-2007, 03:30 PM   #11
spkrman
Drives: 1
They'll laugh in my face if i pull up there with this setup.
The CEL will have to be eliminated before emissions can be considered... not impossible, but a PITA for sure.
Old 05-16-2007, 12:32 AM   #12
tca4
tca4's Avatar
Drives: Yaris RS (white)
does the Zpi turbo kit comes with the blow off valves?
tca4 is offline   Reply With Quote
Old 05-16-2007, 09:02 AM   #13
spkrman
Drives: 1
yea it does:
http://www.zpiracing.net/store/produ...roducts_id=346
not listed on there though, not sure why.
this is the one, apparantly a very sweet one:
http://www.zeropointindustries.net/s...roducts_id=157
Old 05-17-2007, 08:16 PM   #14
joey1320
joey1320's Avatar
Drives: Yaris LB
so you had to remove one of the o2 sensors? if so why?
is that why you have the cel on?
btw nice acceleration. but like chinocharles said the dubs gotta go. if you had some 16-17" with really good sticky tires i think you would like it better.
Old 05-17-2007, 08:37 PM   #15
dngz
dngz's Avatar
Drives: black yaris sedan
is it me or does 0-60 in around 9 seconds in auto is still.... pretty slow...
dngz is offline   Reply With Quote
Old 05-20-2007, 12:45 PM   #16
project y
Drives: yaris
agree i pull a faster 0-60 on nitrous
project y is offline   Reply With Quote
Old 05-20-2007, 12:47 PM   #17
yes, but with heavy-ass 20" dubs?
Old 05-20-2007, 12:50 PM   #18
project y
Drives: yaris
so its still not that fast for the cost
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 05:35 PM
I want to know what is the speed, acceleration and gas mileage of my Yaris kidman General Yaris / Vitz Discussion 13 05-08-2007 04:10 PM
top speed? cptsenestpc General Yaris / Vitz Discussion 33 11-01-2006 04:21 PM
