Old 07-14-2016, 02:13 PM   #1
rabbito
rabbito's Avatar
Engine breather filter?
anybody using one these engine breathers on N/A engine? any gain? let me know the detail please, thanks
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 07-14-2016, 03:19 PM   #2
Jason@SportsCar
If you think that provides a power gain you have no idea what it is for.
Old 07-14-2016, 03:24 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
The only reason to install a vent is if your PCV system cannot keep up with the crankcase pressure. Typically only happens on boosted engines, or sometimes if the motor is doing high-RPM track-days (or if the rings are badly worn). There are some vehicles where the PCV oils will clog up various parts of the engine, and I would consider modifying or removing the system, but the Yaris is not one of them.
I'd spend your money elsewhere unless I am missing something.
Cheers.
Old 07-14-2016, 04:06 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Pulling no punches lol.
Almost make a non-gear head like me afraid to ask questions. Almost
Old 07-23-2016, 08:34 PM   #5
SirDigby
Drives: 2007 yaris 3 door
i'm pretty sure these filters just leave your crankcase unpressurized. (?) I don't see an advantage except the crank vapors do not get vented to the intake system. I would think you'd want the crankcase to remain pressurized during high acceleration to reduce piston blow-by, and this is the reason I would not use one of these...
Really Bad Engine Sludge... monchito18 DIY / Maintenance / Service 27 05-14-2014 11:47 AM
F/S Engine Breather Catch Can 1NZYaris1 Items for Sale by private party 2 03-05-2010 10:29 PM
Air Filter head fell off! Check engine came on! Syroyizhka General Yaris / Vitz Discussion 23 05-06-2009 12:41 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
