Old 07-21-2016, 10:22 AM   #1
fredovvti
Drives: Yaris 07 HB
OEM Power Door and remote Keyless entry
Hi All,
I noticed my yaris have OEM power door and keyless entry. I found to the door Control Receiver. Its a way that a I buy the key with the beeper and program to my Yaris?
fredovvti is offline   Reply With Quote
Old 07-22-2016, 06:58 PM   #2
ricardocanedo621
ricardocanedo621's Avatar
Drives: 2008 Yaris Base
HYQ12BBX should be the remote for your car.
06-10 Toyota Yaris Remote Programming Instructions
Driver’s door open, key removed from ignition switch
Within 5 seconds: Insert and remove the key from the ignition switch twice
Within 40 seconds: Close and open driver’s door twice. Insert and remove the key from the ignition switch
Within 40 seconds: Close and open driver’s door twice. Insert the key into the ignition switch and close the driver’s door
within 40 seconds: Switch ignition ON and OFF once to program a key remote transmitter code whilst retaining the original codes or twice to program a key remote transmitter code whilst erasing the original codes. Three times st o check how many key remote transmitters are currently registered or five times to erase all registered codes
Remove the key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
Within 45 seconds. Press and hold LOCK and UNLOCK button simultaneously for 1.5 seconds
Within 3 seconds: Pres and release LOCK or UNLOCK button
System should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
Within 45 seconds: Repeat button procedure to program remaining remote transmitters
NOTE: To exit programming mode: Open driver’s door
NOTE: A maximum of 4 key remote transmitter can be programmed.
ricardocanedo621 is offline   Reply With Quote
Old 07-22-2016, 07:01 PM   #3
fredovvti
Drives: Yaris 07 HB
Thank you
