Old 07-24-2016, 03:51 PM   #1
mrdgzpm
Drives: Mikes 2013 Yaris
2013 Yaris LE was completely powerless...
I have a 2013 LE 4 door and today I got in to start it up and it was completely dead as far as power. No headlights, accessory lights, interior light, radio, nothing at all. While I was on the phone with AAA all power came on and was able to start like nothing ever happened. The battery (interstate) is 3 months old. Any thoughts?
mrdgzpm is offline   Reply With Quote
Old 07-24-2016, 04:27 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Check that both battery terminals are tight almost sounds like the main fuse the 120 is going... Located on the positive side terminal, will show 120 and 60.
Sent from my Nexus 5X using Tapatalk
Old 07-24-2016, 09:04 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
Battery cable connector terminal pinch clamp Corolla
tight and clean. And, 91 Corollas had a plastic washer under the battery cable connector with a flange that stopped the pinch clamp from pinching enough. Bad idea that needed removed.
"Clean":To varying degrees, a non-conductive crust layer forms between battery terminal and connector. Needs sanded, scraped and/or wire brushed. (There's a little round tapered tool that brushes both sides of the joint.)
Toyota Yaris 2013 Wing Mirror Indicator Cover sujan DIY / Maintenance / Service 2 12-23-2014 12:25 PM
Drove a 2013 Fiat 500 for a week; Love my Yaris even more CTScott General Yaris / Vitz Discussion 47 05-16-2014 07:22 PM
