Old 07-26-2016, 07:07 PM   #1
a400
Ryan
Drives: 2013 Yaris LE 4 dr
2013 Yaris TRD rear sway info needed
Want to find/buy a TRD rear sway for my 2013 Yaris I'm in Canada and having hard time finding one to buy.
I'll end up buying from Fargo ND and make a fam trip out of it.
My questions are: any better places to buy either Canada or USA ? Part number ?
Did some searching and didn't find enough solid info.
Thanks
Ryan
a400 is offline   Reply With Quote
Old 07-26-2016, 07:52 PM   #2
Turk188
Drives: 2016 Yaris 3 door
I've been looking myself. I'm looking at a different set but I did see this in passing.
http://www.oempartworld.com/2396_PTR11-52071
I have a 2010 and a 2016 yaris, they look the same to me. If your on the fence I'll try and get some measurements of the two to compare.
Turk188 is offline   Reply With Quote
Old 07-26-2016, 08:02 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Q2) Part Number: PTR11-52071
Old 07-26-2016, 09:17 PM   #4
a400
Ryan
Thanks for the #.
What are your thoughts for a front strut bar ?
I only want to do some mods to car and not sure if strut bar would be worth it ?
Any type recommended ?
Old 07-26-2016, 11:25 PM   #5
SirDigby
Drives: 2007 yaris 3 door
the front is fine. no need to upgrade. you can if you want, but not needed. SOMETHING IS needed in the rear....
I bought the whiteline 23mm because it's bigger and I really like how it looks.
I bought it off carid.com
it was on sale at the time....
Old 07-27-2016, 06:13 AM   #6
a400
Ryan
Awesome, thanks for link turk188. Think I'm gonna go w them, ship to just inside USA,pick up , install.
Old 07-27-2016, 06:14 AM   #7
a400
Ryan
Someone did mentioned 07 to 11 did fit. Can that be confirmed ?
Old 07-27-2016, 12:08 PM   #8
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Yep, the 07-11 Yaris TRD rear-sway-bar does fit the 2012-2016. I have it on my 2015 SE, and it was a perfect fit.
The 2012-2014 SE-trim, however, requires same-grade bolts with a different thread-type to accommodate the dampeners that are installed in the same bolt hole as the sway-bar uses (which isn't an issue for the 2015/2016 SE) - so you cannot use the bolts provided with the TRD rear-sway-bar without removing the dampeners. Other than that, no issues using it on the 2012-2016 Yaris.
More-detailed info in this thread:
http://www.yarisworld.com/forums/showthread.php?t=52593
Kalispel is offline   Reply With Quote
Old 07-27-2016, 08:51 PM   #9
a400
Ryan
Perfect, this was he confirmation I was needing before ordering. Thanks
FS: TRD Rear Sway Bar - $100 OBO richard_rsp Items for Sale by private party 24 04-26-2016 12:05 PM
FS: trd rear sway bar springs and injen cold air intake dailygrindin Items for Sale by private party 27 12-11-2012 10:12 PM
FS: TRD rear sway bar Cosworth Items for Sale by private party 18 10-05-2012 06:59 PM
