Old 08-09-2016, 12:33 AM   #1
rabbito
rabbito's Avatar
Shifting on Automatic Transmission
i took this from youtube but this ones only E85 converted and slightly tuned(E85), so its pretty much stock 1NZ with 4speed. anyways i see some people kept on asking how people shift through the gears on AT..you can actually shift L(1)->2->3->D without any issues...dont let go of the acceleration when you shift...just shift up when your about to red line...
https://youtu.be/x7Sw6Hddph0
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 08-09-2016, 01:11 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes of course you can manually shift an automatic transmission. And whoever filmed that video should have focused on the tach instead of the speedo.
Old 08-09-2016, 02:43 AM   #3
rabbito
rabbito's Avatar
let me do a video later tonight 😂😂😂😂
Old 08-10-2016, 11:52 AM   #4
rabbito
rabbito's Avatar
damn...i filmed it with my dash cam but cannot load...fml...ill do it again in few days lol
Old 08-11-2016, 09:42 PM   #5
MadMax
MadMax's Avatar
Yes, you can always manually shift an automatic transmission; but you'll never get a manual transmission to shift automatically!
Old 08-15-2016, 11:04 AM   #6
bassmannate
Drives: 2008 Toyota Yaris
I've driven manual my whole life. The only auto trans I've ever had my name on the title is my wife's yaris so i don't have a ton of experience with auto. Does shifting like this shorten the life of a transmission at all?
Sent from my LG-H811 using Tapatalk
bassmannate is offline   Reply With Quote
Old 08-15-2016, 01:56 PM   #7
rabbito
rabbito's Avatar
i just posted up a video, check it out.
hmmm....here in thailand they beat the auto transmission but i dont see anyone having issues yet. people here like to use performance fluids(hks etc) since japans close to thailand and parts/products are much cheaper than u.s...
i beat mine reving all the way through and im not having any issues yet...of course i drive on D mode but when i hit the free way with bunch of curves its on 😤😤😤😤
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Shifting Problems Automatic Transmission Surubi DIY / Maintenance / Service 3 03-14-2016 01:52 PM
Automatic Transmission to Manual Zarkos Performance Modifications 3 05-22-2014 12:24 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
