Old 08-14-2016, 10:36 PM   #1
jaybowblue
Drives: 2007 yaris
Engine misfire problem
Okay, i've had one heck of a time trying to solve this misfiring issue and i'm hoping someone can help.
2007 yaris at 195000 miles. Had the water pump and the headgasket replaced a couple months ago
a week ago i got a check engine light, had the code read, it was misfire on cylinder 3
...so i had the sparks replaced
after about 40 minutes of driving again i get the same code
...so i replace the coil (probably should have just swapped them to see if the misfire moved but i was impatient)
after a bit the misfire reoccurs
Considering i just had the headgasket done i wanted to ensure i was getting enough compression, had 3 and 1 tested, they were fine.
the guys who did my headgasket said the intake valve looks good and engine was in good condition.
They suggested the next step might be to swap injectors to see if problem follows it....
which i did today and....
now i have a misfire on 1 2 and 4.
So i'm worried that i did something wrong. The task itself seemed easy enough, remove the two bolts holding the injectors, move the metal pipe holding them up so that i can access them, wiggle them out and exchange?
Did i potentially turn a single misfire issue into something bigger by doing something wrong or does the 1 2 4 tell us something more and i'm just not able to connect the dots.
jaybowblue is offline   Reply With Quote
misfire
Engine Power problem johnnashfcup DIY / Maintenance / Service 5 12-16-2015 06:40 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
