Old 08-26-2016, 02:28 AM   #1
joemarsh2004
Drives: 2012 yaris 1.33
2012 yaris 1.33 engine knocks down when i turn it off
Morning guys,
Just bought a 1.33 2012 Yaris and when I shut the car off it sounds like a diesel. Clatters on shut off for about 2/3 seconds.
Anyone else experienced this, is this normal for that engine or have I got a problem
Thanks
Joe
joemarsh2004 is offline   Reply With Quote
Old 08-27-2016, 07:29 PM   #2
SirDigby
Drives: 2007 yaris 3 door
check injectors for leak. that's like the only thing I think it could be...
no. vary not normal.
Old 08-27-2016, 09:16 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
I'm not familiar with the 1.3L, but that is very odd for an injected motor to "run-on" or "diesel". Odd enough that I've never seen it on an injected motor in 20yrs of dealing with cars. If it is dieseling, it means you have both fuel and ignition. Fuel could be leaking injector as mentioned, or engine oil. Ignition could be hot carbon deposits or valves. High idle RPM also contributes as it makes it easier for the engine to keep going. At the end of this (loud) video, there is an example of what dieseling looks like: https://www.youtube.com/watch?v=uv1tgSWWlHQ
It could also be something totally different in that maybe one circuit of the ignition switch is not turning off. So maybe your ECU is still powered and commanding it to run, but the fuel pump has shut off. You would expect to have some obvious electrical problems at the same time though.
Cheers.
2012 Yaris LE part out ucsmfu Items for Sale by private party 31 10-02-2019 05:04 PM
Information for 2zr fe engine swap in my 2012 ncp131 Yaris 20yaris12 Third Gen Yaris General Discussion 0 07-02-2016 11:54 PM
