Old 09-02-2016, 03:09 PM   #1
Meechity
Drives: 2010 Yaris sedan, AT
Send a message via AIM to Meechity
AT Sedan - pulsing sound on deceleration
After a long drive, when I decelerate, at about 1000 rpms there is a pulsing sound. The sound itself decelerates and stops with the vehicle speed, if that makes sense. It sounds like Curly from the 3 Stooges — that's the only way I can describe it. "Woob woob woob woob woob."
The sound isn't very apparent when the car is first driven, but after a 70 mile commute and pulling into the parking lot at work it is quite loud.
I do NOT have to press on the brakes for this sound to happen, although that certainly helps me reach the 1000 rpms.
Shop thought it might be a stuck brake caliper and a warped rotor, but they think it might be the transmission.
Any ideas? :)
2010 Yaris Sedan, AT, 243,000 miles <(not a typo)
I love my Yaris, but I miss my Echo...!
Meechity is offline   Reply With Quote
Old 09-16-2016, 05:12 PM   #2
Meechity
http://www.wikiupload.com/7LE0YI8ZQGQB91J
Audio Clip link above. I tried to attach but there is no option for video or audio.
Old 09-16-2016, 08:04 PM   #3
your link doesn't work for me.
But you're probably just hearing the exhaust reverb. As the engine comes down on fuel cut, it comes to a point around 1000 or so RPM where fuel needs to turn back on and you sometimes get a bit of a lean mixture poping in the exhaust system.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
NEW SOUND IN MY YARIS SEDAN shangapol Cosmetic Modifications (Exterior/Interior) 3 03-19-2010 06:51 PM
09 Sedan Struts?? supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-01-2010 01:20 PM
