Old 09-12-2016, 09:06 AM   #1
Jsphonorio
Drives: 2007 yaris hatch
2007 Yard disconnect antenna
Hi everyone. I just bought a 2007 Yaris 2d hatch that I'm loving. The only issue I have is due to the lack of an aux input I am using an FM transmitter. My area has a ton of radio stations which lead to interference and I never use my radio. What is the easiest way to disconnect the antenna in order. I don't need to remove it but just unplug it. Would it be easier to disconnect it closer to the antenna or from the back of the radio?
Jsphonorio is offline   Reply With Quote
Old 09-12-2016, 09:35 AM   #2
Very easy to remove the radio.
http://www.yarisworld.com/forums/showthread.php?t=556
Old 09-12-2016, 09:44 AM   #3
Jsphonorio
Thanks that does look easy enough. Pop off the plastics. Unscrew and just unplug the antenna cable and put it back together. Thanks!
2007 Hatchback install antenna shark echadow Cosmetic Modifications (Exterior/Interior) 9 06-01-2013 03:19 PM
Where I can install the GPS external antenna for Yaris Sedan 2007 DerKaiZeRs In Car Entertainment + Electronics (audio / video / alarm) 4 10-02-2009 12:24 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
