Old 09-24-2016, 11:00 AM   #1
senthilselvaraj
Drives: Yaris Sedan 2013
Unhappy Yaris 2013 Steering pulls!!!
Dear All,
Am driving yaris 2013 model for two years. But currently am experiencing a slight pulling of my steering towards right side when am crossing 80Kms speed. Its normal below 80. I set alignment already. What can i do further? Please guide...
senthilselvaraj is offline   Reply With Quote
Old 09-24-2016, 01:06 PM   #2
fatpanda
Drives: 2013 Yaris SE
1)You mentioned doing an alignment. Did you change any components? Is there any play in the inner tie rod end?
2) Are your tires balanced? weights do come off time to time.
fatpanda is offline   Reply With Quote
Old 09-26-2016, 08:20 AM   #3
Justhandguns
Drives: Yaris Icon 1.33
Originally Posted by senthilselvaraj View Post
Dear All,
I would first check from the minor things.
1. Are the tyre pressures uniform?
2. Any hits on kerbs or humps recently?
3. Any non-uniform wearing of a particular tyre?
4. Any adjustments or modifications done to your suspensions recently?
5. Car battery at the correct voltage/current?
Then I would probably think of wheel alignment (again, did you do it with Toyota or somebody else?) or checking the power steering motor or the steering column itself.
Justhandguns is offline   Reply With Quote
Old 10-19-2016, 09:55 PM   #4
YodaBird
Drives: Gray
I noticed the left front tire had way below 30psi; that is the tire used for left hand turns, no surprise; every other tire was good.
YodaBird is offline   Reply With Quote
So how are you liking your 2012 & 2013 Yaris SE? The Squirrel Mafia Third Gen Yaris General Discussion 32 04-14-2014 02:30 PM
Steering column compatibility between Euro Yaris and US Yaris Micropurchase Third Gen Yaris General Discussion 19 09-17-2012 12:00 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
