Old 10-05-2016, 07:21 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
A/C always on
Seems the A/C on my 08 Yaris is always cycling on when vent is set to defrost position,why is this and is there a way i can turn off this automatic feature?
Thanks
Have Yaris will travel..
Old 10-05-2016, 08:33 AM   #2
A/C is on to augment the defrost setting to help remove moisture from inside the vehicle. This greatly improves the ability to remove and prevent fogging on the window glass.
There are many discussion on this feature as well as queries on bypassing it. Search them out. I'm not going to. I think the easiest way might be to run a shorter serpentine belt and bypass the a/c pulley.
Old 10-05-2016, 11:43 AM   #3
bronsin
bronsin's Avatar
Yes it helps greatly to defog the windows.
It bothers me too but it sue would suck to hit something because I couldn't see out of the car!
There are mods in here to prevent the ac going on with defrost.
Old 10-07-2016, 08:02 AM   #4
jambo101
jambo101's Avatar
I remember seeing a thread on disconnecting that feature but i`m having no luck finding it again.
Old 10-07-2016, 09:22 AM   #5
You have posts in both of these threads
http://www.yarisworld.com/forums/sho...=disable+a%2Fc
Old 10-07-2016, 11:35 AM   #6
jambo101
jambo101's Avatar
Thanks.
Old 10-16-2016, 07:24 PM   #7
SirDigby
Drives: 2007 yaris 3 door
I remember my civic would do this too. on the civic you would turn all the dials all the way to the right, press and hold the rear defrost, recirc, and a/c buttons, then you would turn the ignition switch on. it would turn off the auto defrost. switches to the right to turn it on.
I have not found a procedure for Toyota yet...
A/C turning off when idle jmandawg DIY / Maintenance / Service 19 09-03-2023 07:02 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C compressor yaryar83 General Yaris / Vitz Discussion 3 06-03-2012 09:47 PM
