Old 10-08-2016, 11:36 PM   #1
stance
Drives: yaris
Pression tire with stance
Salut j'ai une yaris 2007 avec des coilovers et j'aimerais savoir a quel pression je devrais mettre mes pneus...il demande 32 avec les stock
Hi i have a yaris 2007 with tein coilovers and i would like to know the perfect pression for my tire...stock tire is 32 psi and my tire is 185/60r/15
stance is offline   Reply With Quote
Old 10-10-2016, 03:14 AM   #2
jcboy
Drives: Sedan 07
Did yo mean pressure for your 185 60 15 tires?
If i remember right my door jamb says 30 psi front 28 psi rear without passengers. 30psi rear of there are passengers.
You will be alright even with up to 35psi, i run 36 or 37 and ride gets a bit stiff and eats up tires faster. Youll be alright with 32 or 33.
Sent from my G9208SS using Tapatalk
Old 10-11-2016, 12:56 AM   #3
CoryM
Drives: 2009 5-door, 5-speed
If you aren't cornering hard, you will probably see the best tire life at around 34-36psi front, and 30-32psi rear.
Stance wheel and tire questions. Thebigwicks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 05-26-2015 07:49 PM
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
