Old 10-20-2016, 11:01 AM   #1
rabbito
rabbito's Avatar
Noise Sealing tape
i bought thess few days ago try to reduce noise down after all the damping i did on the doors and floors..i saw people sticking these around the door frame but instruction clearly says put it right next to stock oem door seal...i wasnt even hoping much with $60 door seals...😏😏😏
the result was great!!, i dont even hear slight wind noise anymore...😲😲😲
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Colour Collection 05 Reg (UK) brake noise JLx DIY / Maintenance / Service 0 07-14-2015 06:56 AM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 12:20 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
