Old 10-21-2016, 04:29 AM   #1
rabbito
rabbito's Avatar
What tires are you guys running?
I am running hankook v2 concept 2 195/50/15 with TRD rims...its not the best set of tires but it does the job..👌👌👌👌👌
better than dunlop sp that came as stock...sliding everywhere and hella noisy...hope i saved up a little bit more and go for hankook RS3s..😣😣😣😣
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
All terrain tires for cars? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 11-01-2013 11:05 PM
Kumho Ecsta ASX Tires MadMax Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-01-2013 04:32 PM
My 17" alloy rims and Kumho tires... will swap for your original wheels! AutoWashCars NY / NJ/ CT / PA 5 02-08-2011 07:38 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
