Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-27-2016, 10:39 AM   #1
Mailo
Drives: Yaris TS Turbo
Stock Yaris TS Turbo TRD - Gains in HP and stock engine limit
Hi guys
Thanks for a great forum with vast knowledge within.
I've just bought a stock Yaris TS Turbo TRD from Stockholm.
I'm interested in knowing if there are any straightforward gains in HP and the limitations of the internals of the engine.
I'm no power hungry guy, I'm just looking for around 30-50 HP reliable gains on top of the stock 150 HP. Keyword here is reliable, as it is my daily driver.
I think aftermarket parts are very hard to find, given the rarity of the car. I'm looking for a FMIC as one of the first things on my to-do list.
What kind of bar/psi is it running stock?
Can the engine on stock internals handle a 30-50 HP gain?
Is a simple chip tuning enough?
I'm very thankful for any answers.
Kind regards
Mailo
Mailo is offline   Reply With Quote
Old 10-27-2016, 11:41 AM   #2
Man, I so want your power.
1.8l factory turbo generating 150hp vs the 1.5l n/a generating 106hp that we have to play with. Consider yourself fortunate to have such a desirable starting point.
Sorry I cannot help you on what you can do to achieve your end game. I'd hazard a guess that stock internals are enough to handle at least an additional 30hp given that we push our 1.5l to 140hp on stock innards.
Old 10-27-2016, 11:48 AM   #3
Mailo
It is the 1.5 litre 1nzfe engine that I have :) It is just tuned by TRD with a bolt on turbo kit.
Old 10-27-2016, 11:50 AM   #4
Really? I guess I'd gotten to the point where I assumed the TS was always 1.8l.
Now I'll have to say internals are maxed out.
Old 10-27-2016, 12:07 PM   #5
likely intake, exhaust, bigger intercooler and a tune
Old 10-27-2016, 02:21 PM   #6
Mailo
Thank you.
Can the stock engine handle the additional power?
Old 10-27-2016, 02:22 PM   #7
Mailo
Really?
Is there no leg room for a little more power?
Old 10-27-2016, 02:51 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
intake, exhaust, bigger intercooler, boost controller and a tune definitely. The turbo starts to run out of steam at about ~175hp though.
Old 10-27-2016, 02:53 PM   #9
180-200 is probably the limit to a stock internals 1NZ. That being said, it's all in how well it's tuned. A front mount intercooler and a good tune, with the relocation of the Intake Air Temp sensor to the actual charge pipe will lead to the most reliable addition of power without getting into the engine.
Old 10-27-2016, 03:13 PM   #10
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
If the car is already turbo-ed, I suspect you won't get much more than another 10hp or so, by conventional measures. Also Toyota ECUs are usually locked against chip upgrades. Maybe with a turbo's piggy-back ECU that's different.
150hp in a small, light car, like a Yaris, must really fly!
Sent from my LG-D801 using Tapatalk
Old 02-09-2024, 06:03 AM   #11
Noradat
Drives: Man
Send a message via AIM to Noradat Send a message via Yahoo to Noradat
Can the stock engine of your Yaris TS Turbo handle the additional power from intake, exhaust, a bigger intercooler, and a tune, considering the turbo starts to lose steam at around 175hp and the potential limit for stock internals is around 180-200hp?
Noradat is offline   Reply With Quote
Old 02-12-2024, 02:16 PM   #12
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
No the internals of the engine are already at their limit, i've seen plenty of people shoot a rod through the block on standard TS turbo specification.
Intake exhaust sure but no more than that, maybe on standalone with a very safe tune sure.
But my 2 cents don't chase power on stock internals as it will blow up one day.
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
