Old 11-06-2016, 08:12 AM   #1
bronsin
bronsin's Avatar
Photo: Sparkpluug After 136000 Miles
I got the plugs out of my wifes 05 Camry by following the advice of this excellent forum: warm the engine up first. Piece of cake. Its hard to believe how stuck they were with the engine cold. The plugs have 136k on them.
Therefore I am withdrawing my advice to anti seize the plugs of your car if you plan to leave them in for 100+k miles.
Heres a pic of one of the plugs. Gap was 040 I think new is 032. Engine didnt start or run any better that I could tell. If it was my car Id regap and reinstall them.
Old 11-06-2016, 09:57 AM   #2
alanwagen
no antiseize with NGK
If you use anti-seize you could over torque your plugs. Not even necessary with NGK plugs.
"NGK spark plugs feature what is known as trivalent plating. This silver-or-chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without the use of anti-seize. NGK tech support has received a number of tech calls from installers who have over-tightened spark plugs because of the use of anti-seize. Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage."
https://www.ngksparkplugs.com/about-...ut-spark-plugs
Old 11-06-2016, 10:26 AM   #3
jra
Drives: 2015 yaris L
When steel is in contact with aluminum it causes a chemical reaction, causing the aluminum to corrode and the steel to rust.
jra is offline   Reply With Quote
Old 11-06-2016, 10:34 AM   #4
bronsin
bronsin's Avatar
When the engine was cold you could NOT get them out, plating or no plating.
Very easy if the engine is warmed up.
Old 11-06-2016, 09:41 PM   #5
jcboy
Drives: Sedan 07
Dont use antiseize. Just torque them 1/4 turn after its on there tight.
With this you can remove them cold now. Try to avoid removing them warm, as aluminum heads of newer engines are more prone to loosethread than iron heads.
Sent from my G9208SS using Tapatalk
Old 11-06-2016, 10:06 PM   #6
I don't know how tight you guys torque your plugs, but with the temp changes an engine experiences I've always anti seized my plug and just hand tighten down lightly. Never even close to issue of stripping from over tightening.
I've yet to come across anyone having an issue of fouling plugs from using anti seize. I've heard the story before form manufacturers about not needing to lubricate their parts because of some unicorn coating only to have them seize solid. I'm going with my gut and past experience on this one.
I also tend to remove plugs cold to reduce risk of thread damage on the soft head.
Old 11-07-2016, 07:36 AM   #7
bronsin
bronsin's Avatar
Hand tighten aniseized plugs with an easy does it force makes sense.
Using a torque wrench with same is asking for it.
If hot removal can damage the threads then I'm for antiseize/cold removal.
But I had no trouble with hot removal/no antiseize this weekend.
Course I have a lot of experience and am cautious.
Best thing I think is remove the 125k plugs before 125k! Then you can go cold/no antiseize
Finally, 450,000 miles on my 07 Yaris in 5 years trini_per4mance General Yaris / Vitz Discussion 36 12-07-2011 07:41 AM
Is every 24,000 miles correct for replacing serp belt? JerseyJeff84 DIY / Maintenance / Service 11 09-09-2011 06:35 AM
2 Good Yaris Engines Under 100 Miles, Parting Out. 42 Autosports Items for Sale by private party 36 02-15-2011 10:00 AM
smokey 1.4 D - only 52K miles BigLebowski General Yaris / Vitz Discussion 6 11-05-2010 03:04 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
