Old 05-17-2007, 10:01 AM   #1
abdiel hiram
abdiel hiram's Avatar
Drives: Yaris HB 2005
Se Vende
Se venden los siguientes ITEMS en Conjunto o Indivualmente
Contacto: Abdiel
Telefonos: 300-9649 o 6611-8178
Equalizador Kicker -KQ5 5 Band EQ 03KQ5
Descripcion:
5-Band Parametric EQ
2 Sets of RCA Inputs
Frequency Ranges:
Bass: 40 Hz - 90 Hz
Midbass: 125 Hz - 250 Hz
Upper Midrange: 300 Hz - 750 Hz
Upper Midrange: 1 kHz - 4 kHz
Treble: 6 kHz - 20 kHz
Cut/Boost: +/- 12 dB
Input Sensitivity: 950 mV - 9.6V
Output Level: 7V RMS
Front/Rear Fader
Remote Bass Level Control: Control your Kicker amp's bass boost from the EQ
EQ Defeat/Bypass
Line 1/Line 2 Input Selector
Dual Illumination Green/Orange
Crossover Kicker KX3
Front and Rear High Pass Crossovers - 18dB/octave, Variable
Frequency (35-400Hz; 20x Multiplier Option on Front Crossover)
Sub Low Pass Crossover - 18dB/octave, Variable Frequency (45 250Hz)
Bass Boost Variable to +18dB at 40Hz
Remote Level Controller
24dB/octave Subsonic Filter
Two Stereo Inputs with Parallel Input Option
Three Stereo Outputs (5V rms)
Signal-to-Noise Ratio - >110dB
1-year Sonic Electronix warranty
Amplificador - Directed A1004 Amplifier 4 Channel
Model A1004
Max Power Rating 1000 watts
CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 85W x 4
CEA S/N Ratio (referenced at 1 watt/4 ohm) 81dB
CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 125W x 4
@ 2 ohm
Freq. Range 20-20K Hz
Damping Factor >100
Input Sens. 250mV to 7.5V
Crossover var. 12dB
2-way
Bass EQ Yes 8db
RCA Output Yes, stereo
Protection T,S,D,R,O,L
Dimensions - inches W:16-7/8
H:2-1/2
L:13
Metric - mm W:273
H:63.5
L:430
Todo el Paquete se vende en $350, Individualmente, el AMP se vende en $200 y el Crossover y EQ se venden Juntos en $150.
Se aceptan Ofertas.
Abdiel Hiram
Old 05-17-2007, 10:06 AM   #2
Fer.pa
Fer.pa's Avatar
Drives: Yaris HB
Send a message via MSN to Fer.pa
vi el post en latinol. Sha kicker... cuanto pide x el eq? tiempo de uso ..
Super Yaris Panamá
05 HB - 2NZFE 1.3L Engine - 068 Super White - Aem CAI - Trd Oil Cap - Rev 17" rims -Toyo 205/40/17 wheels - Vibrant Front Strut Bar - Tein-S springs - KYB Gas Shocks - Header DC-S 4-1- Tenzo-r steering wheel- Pioneer Avh-P 5750
Fer.pa is offline   Reply With Quote
Old 05-17-2007, 10:16 AM   #3
abdiel hiram
Si, es de un compañero del Job que me pidio el favor. El tiempo de uso es promedio un año. Parece que quiere vender el Eq con e CRossover juntos. serian 150 ambos.
Abdiel Hiram
