Old 11-14-2016, 09:48 AM   #1
vidfan
Drives: 08 yaris
Head gasket location and part
So the dealership just diagnosed my car with a leaky head gasket. Not paying the high price for them to do it. Does anyone know by chance know where type of gasket is installed on an 08 Yaris Sedan and the type of gasket installed? Trying to avoid using a third party part if possible.I tried googling for the information but can't find anything concrete. Thanks for the help.
vidfan is offline   Reply With Quote
Old 11-14-2016, 10:19 AM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
A quick search produced this thread which has a write up...
http://www.yarisworld.com/forums/sho...ht=head+gasket
Hope it helps.
On Instagram
On Wheelwell
Old 11-14-2016, 12:17 PM   #3
Hershey
It may not be the head gasket . Most likely to be the timing chain cover . This is very common . Reason being the white gasket sealer from the factory .
Old 11-14-2016, 12:29 PM   #4
Hershey
Does it look like this in the video ? https://www.youtube.com/watch?v=EVK_uBKotcU ( PAUSE around 23 seconds ) . If so , it's probably the sealant . You can see it in the video .
Old 11-16-2016, 06:16 AM   #5
vidfan
Drives: 08 yaris
Thanks for the replies. I haven't looked at it yet myself, but the dealership mechanic said there was coolant bubbling around the gasket per their observation.
Old 11-17-2016, 12:57 AM   #6
SirDigby
Drives: 2007 yaris 3 door
to answer your question, the head gasket is a large seal that spans the length of the engine. it is located below the head. (under where the intake manifold is bolted to the engine) if you replace it, the leaking timing cover that is suggested above will also be removed and resealed when assembling the head back on.
the type of gasket is a metal crush type.
don't discredit 3rd party on this repair, as it's been a common repair for over 100 years, and almost every engine is built the same way and will be repaired in the same manor.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
