Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 11-16-2016, 04:19 PM   #1
Fourbears
Drives: Toyota Yaris SR 1.3
EML issues
Hi there, I am hoping that someone might be able to help me. The EML keeps coming on on my 2000 Yaris 1.3vvti SR despite replacing the MAF sensor and the front cat sensor. I am at a loss now as to what it may be so if anyone has any ideas I would gratefully accept them. I did try a fault code reader and it came up with bank 1 lean which indicates one or other of the sensors I have replaced, or so I am told. I have disconnected the battery each time for more than 15 mins to reset the ECU but after a few miles the light comes on again. Any ideas?
Thanks in advance.
Fourbears is offline   Reply With Quote
Old 11-16-2016, 10:15 PM   #2
Have you checked for vacuum leaks?
Old 11-17-2016, 01:00 PM   #3
Fourbears
Hi yes I did, as far as is possible. I forgot to mention that.
Old 11-17-2016, 01:06 PM   #4
how did you check all areas?
Old 11-17-2016, 01:22 PM   #5
Fourbears
By re-seating all the pipes and checking for splits etc. Of course there may be pin pricks that can easily be missed. It seems that a vacuum leak is the culprit.
Old 11-17-2016, 02:21 PM   #6
It's a lot easier to use a spray like starter fluid or carb cleaner on every joint including where the manifold bolts to the head.
You should also check your plugs for any one lean cylinder.
Old 11-19-2016, 05:27 PM   #7
Fourbears
Thanks for the suggestions but I have found the culprit - the cat has failed. I managed to get the codes read properly and the cat came up straight away. Looks like the end of the road for this one!
Old 11-19-2016, 05:58 PM   #8
What code numbers came up.
A bad cat is P0420
Old 11-20-2016, 01:10 PM   #9
Fourbears
Thats the one! As the headlamps are somewhat opaque, the brakes need either new drums, discs or both plus the cat and it has 162k on it it is not economic, for me, to repair it for the MOT due in Feb. So it will have to go closer to the time.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Signaling issues. NoisyPegasus DIY / Maintenance / Service 8 11-20-2015 10:58 AM
Steering Wheel Jams, Battery Warning Light flickers, Starting Issues tmrtza In Car Entertainment + Electronics (audio / video / alarm) 3 10-31-2014 09:01 PM
Auto insurance issues from modifying a Yaris? RMcG General Yaris / Vitz Discussion 11 06-24-2012 04:38 PM
CV joints or axel issues aucorium DIY / Maintenance / Service 1 02-17-2010 09:10 PM
