Old 11-19-2016, 07:29 AM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
Best way to stop belt from squealing at first startup?
I'm on my 3rd or 4th belt on my 2007 yaris with 125k miles on it. The problem i have is the belt squeals on cold starts. In the past i would keep tightening the belt, but then they eventually snap from the tension. Besides tightening, are there any other options to stop the belt from squealing on cold starts? Thanks
brg88tx is offline   Reply With Quote
Old 11-19-2016, 02:24 PM   #2
SirDigby
Drives: 2007 yaris 3 door
clean belt with belt dressing and toothbrush. also, overtightening belt will cause a squeal. needs to be at proper toughness. not loose, but not too tight. also check pulleys for binding/wore out-ness
Old 11-19-2016, 02:50 PM   #3
brg88tx
Thanks for the reply....after researching a little more i found this posted in another thread here. I was skeptical at first, but this actually works.....no more squeal!!!
https://www.youtube.com/watch?v=HRrVMtyIqIY
Old 11-19-2016, 03:12 PM   #4
SirDigby
wow! that's a great video. I never knew. I always have started my cars slow. I usually let it sit in the "on" position for 3-5 seconds so the fuel pump primes and computer runs checks before starting. very interesting information here...
Old 11-28-2016, 10:15 PM   #5
dave mac
dave mac's Avatar
Drives: '07 coupe Meteorite Metallic
This worked for me too
The guy on the 'Carquestions' video is exactly right, I tried what he said and no more squeal. Simple, just hold at "run" for an extra second before turning the key all the way to start.
dave mac is offline   Reply With Quote
Old 11-28-2016, 10:52 PM   #6
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Keep belt tight enough and use only TOYOTA ORIGINAL !!!
KimmoKekki is offline   Reply With Quote
Old 11-28-2016, 11:23 PM   #7
That's neat! Ok, now someone has to do an experiment with a volt meter hooked up and see if there's a difference in the charge that battery is getting if you start it quick vs. staring it slowly.
Old 11-28-2016, 11:30 PM   #8
Wife always starts right up, never had issues with her Honda for 14years.
My Echo actually did not like it once or twice, so I keep it a habit to wait a few seconds before starting.
Not how you don't have a choice with push button start. :)
Sent from my SM-G930W8 using Tapatalk
Old 12-02-2016, 12:06 AM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Huh...ima have to try this.
Mine squeals often on start up. Nowhere near as bad in the video. Ive probably been thru 5 belts way sooner then needed.
Ill have to pay attention how fast I turn the key
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
New Serptine Belt Squealing aaron21339 DIY / Maintenance / Service 11 10-14-2016 11:43 AM
squealing belt, but a different question Yarflana DIY / Maintenance / Service 4 02-09-2014 12:41 PM
Squealing Belt Noise Toyota3000 DIY / Maintenance / Service 3 07-23-2013 03:06 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
