Old 11-22-2016, 03:45 PM   #1
robkay
Drives: Hatch
Need help with a headlight lens issue
2007 hatchback. I had to pull my headlight lens off to fix something. I didn't do the heat-in-oven thing, I just kept pulling on the lens and cutting the sealant with a utility knife until I could get the lens off.
I've never seen that gray sealant before and it's kind of balled up in spots. Can anyone tell me what that sealant is so I can get some to reseal the lens when I put it back on?
I'm not sure silicone will work because of the housing being polypropylene. You probably have to use a sealant that will stick to it.
Thanks in advance!
robkay is offline   Reply With Quote
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Yaris 2014 headlight issue YarisEP Third Gen Yaris General Discussion 3 12-23-2015 05:16 PM
Headlight Lens Restoration LeetViet DIY / Maintenance / Service 10 10-18-2015 05:30 PM
Headlight Lens Showing Age IGGGY DIY / Maintenance / Service 18 04-19-2013 08:57 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
