Old 12-08-2016, 11:32 PM   #1
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
2009 1KR Yaris engine shuddering in 1st gear
Hello people, I have seen similar questions asked here but mine is a bit different. My Yaris is a 2009 1KR-FE with the 5spd manual transmission. It has about 110,000KMs on the odo.
Since a while back I have noticed that the car shudders quite violently when trying to take off from stand still. I am quite sure it's not related to releasing the clutch early or not giving more gas, because it still does it when the RPM is well above 2000. Even more puzzling is, the car is normal when its cold. In the morning or when I have parked it for some time, it doesn't do the weird shuddering. It starts to shudder when its all warmed up and becomes more violent when I spend time in traffic.
Any ideas why this is happening?
Thanks,
The Surf is still here.... But now there is a Yaris next to it!
tamrat is offline   Reply With Quote
Old 12-09-2016, 12:42 AM   #2
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Sounds like burned clutch plate ...
Do you stand on clutch pedal at traffic jam or select neutral when possible ??
KimmoKekki is offline   Reply With Quote
Old 12-09-2016, 03:22 AM   #3
tamrat
I always put it in Neutral.
I don't know if it's related, but the transmission always grinds when I put it into reverse.
Old 12-09-2016, 03:37 AM   #4
KimmoKekki
KimmoKekki's Avatar
Reverse gear is not synchronized !
Could also be tacking clutch release bearing ...
Old 12-10-2016, 03:09 PM   #5
tamrat
How serious is the problem? Should I take an immediate action?
Old 12-10-2016, 03:41 PM   #6
KimmoKekki
KimmoKekki's Avatar
Can't say yes or no ..
It's quite annoying feature to be honest !
I would change clutch if my car have this kind feature !
Yaris 1KR engine Volcanoman DIY / Maintenance / Service 0 01-10-2016 08:45 AM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
