Old 12-15-2016, 02:55 PM   #1
WillieLloyd
Drives: 2010 Yaris
2010 Yaris Hatchback Brake Light Replacement
The original Toyota manual characterizes being able to pop off the panel in the hatch, doing a quarter turn, then removing the brake light to replace with a new one. Unfortunately, the wiring provides so little excess that it seems impossible to withdraw the bulb from the lens to be able to replace it.
The alternate approach would be to remove the lens from the chassis and replace the bulb from the outside of the car (rather than from the trunk). I removed the two, 10mm nuts and tried to lever the lens off it's mounting, but there seems to be something it is holding on to. I'd rather not apply too much pressure and risk snapping off something important.
Could anyone say which is the proper approach? If it is the second option, any suggestions as to how much pressure to apply and where?
Thanks,
Willie
WillieLloyd is offline   Reply With Quote
2010, brake light, hatch, replacement, yaris
Replace new tail light yaris 2010 Ockert Brand Suggestions - Feedback - Questions 3 02-22-2013 08:16 PM
VSC/TRAC light stays on (2010 Hatchback - Automatic) mxa77 DIY / Maintenance / Service 4 11-28-2012 01:04 PM
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-06-2010 11:39 PM
