Old 12-24-2016, 06:59 PM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Rear Wiper Blade Replacement
Had to replace the rear wiper blade today. Local Toyota dealers and independent parts stores don't sell a simple rubber insert, and aftermarket blades are more expensive than the OEM part.
Online prices for the OEM blade (with shipping) are more expensive than just buying directly from the local dealer... which is just under $10. After talking to the guy at the Toyota parts counter, I got it for $7 plus tax. Took about 10 seconds to remove the old blade and install the new one.
Part #85242 42030
Old 12-24-2016, 08:07 PM   #2
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
I bought a Trico "Exact Fit" 12A from RockAuto for $4.64. It was indeed an exact fit, but I noticed the plastic texture wasn't an exact match. The Toyota arm has sort of a pebbled texture, while the Trico is smooth. I wound up stealing the rubber from the Trico, and inserting it into the original Toyota arm. It fits fine.
scratchpaddy is offline   Reply With Quote
Old 12-24-2016, 08:16 PM   #3
ex-x-fire
Who care about texture of a wiper arm on an economy car?
Next time get a blade at wally world.
Old 12-24-2016, 09:30 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I replaced the rear wiper on my 3rd gen with a 16 inch blade. These are available as Trico 16a or Tridon TRB010. You then have a car with one 28 inch blade and one 16 inch blade. This is a common pack set of replacement blades, and you get more screen area wiped on the back window.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-08-2017, 12:33 PM   #5
chris96
Drives: 2015 Yaris L
Confirmed a 16 inch rear wiper will fit the third gen Yaris. I used a Autozone Duralast 16A wiper blade and it leaves about a half inch gap from the top of the rear window.
File Type: jpg rsz_1rsz_img_20170308_084024084_hdr.jpg (290.9 KB, 62 views)
chris96 is offline   Reply With Quote
Rear wiper motor gone alex22808 DIY / Maintenance / Service 1 11-05-2014 11:27 AM
P1 rear wiper arm on P2 Chariz Cosmetic Modifications (Exterior/Interior) 1 10-12-2014 06:08 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Found A Rear Wiper Blade Replacement jeff618 DIY / Maintenance / Service 8 11-03-2011 10:15 PM
