Old 12-29-2016, 01:41 PM   #1
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Is there a 6 speed trasmisión for a 07 H.B
I feel like my H.B NEEDS ANOTHER GEAR OR IS JUST ME????
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 12-29-2016, 01:57 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
I never felt that with my '07 or my '14. The 4-speed works brilliantly, and I don't sense it over-revving at highway speeds.
Old 12-29-2016, 02:25 PM   #3
Yaris874
Yaris874's Avatar
I don't know I feel when is in the 5 gear on the highway is asking for another gear but
Old 12-29-2016, 03:25 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
there are several threads on th forum about fitting the C160 6 speed gearbox. The frame needs some mods to clear the gearbox. Also the final drive ratio has a bigger reduction, so you end up with the engine revving faster for a given speed.
The 4 speed auto has a taller overall top gear, so the engine revs are lower at highway speed, but anything other than the slightest hill will cause the auto to drop back to third. At least that's what happens with the 2NZ-FE.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 12-29-2016, 03:44 PM   #5
Yaris874
Yaris874's Avatar
I got a 5 speed not auto
Old 12-30-2016, 12:50 AM   #6
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I know. But Kinoma's earlier comment sounded like a reference to the auto.
The five speed manual has a lower final drive, resulting in higher engine revs in top gear compared to the auto. The six speed manual hasa lower overall gearing thatn the five speed, so the engine revs will be even higher at the same speed.
Old 12-30-2016, 12:58 AM   #7
SirDigby
Drives: 2007 yaris 3 door
Basically he's saying the 6 speed has another gear, but due to it's design your top speed will be the same at the end of 6th gear. (I think it tops out even shorter, like 180km) you would need a custom build on transaxle to achieve your desired goal of high speed/low RPM. idk if the final drive can be removed from C150 and installed into C160. I would guess not...
Old 12-30-2016, 06:55 AM   #8
Yaris874
Yaris874's Avatar
Ooh ok
Old 12-30-2016, 07:33 AM   #9
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I The five speed manual has a lower final drive, resulting in higher engine revs in top gear compared to the auto. The six speed manual has a lower overall gearing than the five speed, so the engine revs will be even higher at the same speed.
Wow, that really sucks. However, I now feel a lot better about having an auto.
Sent from my LG G2 with CM13 using Tapatalk
Old 12-30-2016, 09:08 AM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The car will sit at 80 all day long and get great gas mileage. I know it feels like it needs another gear but it really doesn't.
Colin Chapman disciple
Old 12-30-2016, 09:13 AM   #11
The Yaris runs at about 2700rpm at 100kmh, or 2500rpm 60mph.. the echo final is a bit longer and does 2500rpm at 100kmh. But the Yaris really need this extra rev to keep going without the need to downshift to go up a hill.
You should see the first gen xB.. they rev 3000rpm at 60mph.
Sent from my SM-G930W8 using Tapatalk
Old 12-30-2016, 09:19 AM   #12
Yaris874
Yaris874's Avatar
Hey anyone know in wat rpm i should shift if I wanne squeeze the shit out of the gears on the safe side my h.b is base model so I don't have the rpm gauge so I got a shifting light
Old 12-30-2016, 09:47 AM   #13
dogsridewith
Drives: 2007 2-door hatchback
redline revolutions per minute
1.6 L 4A-FE Corolla fwd circa 1991 is redlined at 6250. Encountered mention somewhere here on YW that Yaris is self-governed to 6000 max. (What does it feel like when this is encountered w/ foot on the floor?)
Old 12-30-2016, 11:28 AM   #14
SirDigby
my rev limiter engages at 6500. the peak HP is at 6000, so it should go beyond that... peak torque is at 4200. so shift light would be best set at ....6150?
Old 12-30-2016, 03:31 PM   #15
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
All 3rd Gen Yarii here in Australia have a tacho as standard equipment. The red line is at 6400.
The 3rd Gen manual lists top speed through the gears for the 1NZ-FE manual as 31MPH for 1st, 58 for 2nd, 84 for 3rd and 108 for 4th. These are maximum allowable speeds in each gear, not necessarily the best performance change point. The ECU speed limiter will prevent you reaching the red line in 5th.
Old 12-30-2016, 07:14 PM   #16
why?
why?'s Avatar
Drives: Yaris LB
You can bounce off the rev limiter, I've done it by mistake.
You can buy a tach for not much money. It is a good investment.
Old 12-31-2016, 04:47 AM   #17
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
If you want an even higher final drive, one idea is to try to swap out the final drive from a Corolla automatic to a Yaris automatic. Both transmissions seem to have the same service manual and many of the same parts.
Saddly it's never been attempted as far as I know...
Old 01-01-2017, 10:49 AM   #18
Just buy taller tires
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 01:52 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
