Old 01-07-2017, 05:14 PM   #1
Lightrfire
Drives: 2007 Yaris hatch
2007 yaris passenger airbag recall time to complete??
So I dropped my yaris off to get the airbag recall done. They initially told me it would take 2 hours and when I got there they told me it was a 5 hour repair and the car would need to be left overnight! Wtf! They said the dash needs to be removed in its entirety to change it! Is this true?? Why would they quote a 2 hour repair previously then? I'm worried they will mess up my tach install and radio. Anybody else do theirs yet that has any input on this?
Lightrfire is offline   Reply With Quote
Old 01-08-2017, 05:04 AM   #2
Yes the dashboard need to come off completely.
I saw them remove the dashboard on mine for a rattle fix, and the bag was attached to it. But this doesn't take 5hours.
Sent from my SM-G930W8 using Tapatalk
Old 01-08-2017, 03:28 PM   #3
Lightrfire
Damn...thanks for the response
Old 01-08-2017, 06:46 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Just had mine done late last week. Left it the night before so they could start on it early. Had a 7:15 AM appointment time and they called to let me know it was ready around 10:45 AM. Like you, I was also worried about my double-din head unit, wired microphone, USB to glove box, etc, but I got the car back not being able to tell anything was done. Gotta say I was impressed, but I'm sure it varies from dealer to dealer and technician to technician.
On Instagram
On Wheelwell
Old 01-09-2017, 09:04 PM   #5
Dash removal does not interfere with your radio or other wiring done unless you attached stuffs to the dash.
Old 01-10-2017, 10:46 AM   #6
ern-diz
ern-diz's Avatar
Good point. I guess when you think about it, in most cases everything is attached to the stuff under the dash, not the dash itself (with the exception of the USB cable that runs from the head unit to lower passenger dash, in my case).
Since originally posting about having had this recall completed, I've used the dial to switch from outside air to inside air and discovered that it works a LOT better than it did before. Not sure if they broke something and replaced unbeknownst to me, or just noticed it was binding on something and fixed it. Either way, it rotates from outside to inside air a lot easier with a much more satisfying click back and forth than it did before.
On Instagram
On Wheelwell
Passenger airbag recall/disable airbag? 47_MasoN_47 DIY / Maintenance / Service 20 11-06-2016 03:36 PM
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
