Old 01-11-2017, 11:15 PM   #1
SirDigby
Drives: 2007 yaris 3 door
1nz-fe transmission: difference 05 to 06
so I found this clutch i'm considering purchasing. there is not a listing for a yaris or vitz, but there is a listing for 2000-2006 echo 1nz-fe.
is the spline count and diameter the same? is the throw out bearing the same?
is there anything different?
Old 01-07-2019, 01:24 AM   #2
bobthesilent
Drives: 2011 Yaris HB
I dont know about the manual transmission but the automatic is always the same paired with the 1nz-fe (u340e)
so following that logic, it should be?
bobthesilent is offline   Reply With Quote
clutch, flywheel, transmission splines
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 10:18 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Transmission Difference Sigs New YARIS Purchase Forum 3 01-05-2011 01:33 PM
