Old 01-17-2017, 01:35 PM   #1
dwilden
Drives: Yaris Hybrid
Exclamation 2013 Yaris Hybrid SatNav map problem
Hi,
My 2013 Yaris Hybrid has a Toyota Touch and Go Satnav system. In the cold weather, the map never finishes loading when the car is started - it just displays a spinning disk symbol, even if the car is driven for an hour or more. However if I turn off the ignition and turn it back on, the map loads after a few seconds. This is fully repeatable, ie same happens every morning from cold.
The car is still in warranty, but the dealer is treating it as a software problem. They told me that they would reinstall the map software, but after having the car for a full day, I discovered that all they had done was reset the radio, which did not fix the fault. I think they are now intending to reload the map software, which means leaving the car with them again for a day.
As the problem is temperature dependent, I suspect the fault is hardware related - possibly a memory chip fault - and no amount of software reloads is going to fix it.
Has anyone else come across this problem, please?
Regards
Dave
dwilden is offline   Reply With Quote
satnav fault, touch&go, yaris hybrid
So how are you liking your 2012 & 2013 Yaris SE? The Squirrel Mafia Third Gen Yaris General Discussion 32 04-14-2014 02:30 PM
2013 Yaris SE - Hitch Issues? bm_cricket Third Gen Yaris General Discussion 8 06-16-2013 09:51 PM
Yaris Hybrid Panoramic Sunroof info? 3kgt Third Gen Yaris General Discussion 11 06-29-2012 01:37 PM
