Old 02-04-2017, 10:01 AM   #1
wng-2
wng-2's Avatar
Drives: 2008 Yaris Hatch back
Headlamp Change
Any tricks to changing a driver's side headlamp on a 08 without taking the whole car apart? Thanks.
Rich,
Berwick, Maine
wng-2 is offline   Reply With Quote
Old 02-04-2017, 02:10 PM   #2
JessMess
Drives: 08 Yaris hatch back
you need to find someone with tiny hands...
I have large hands and have to take the bumper off and headlight out everytime
JessMess is offline   Reply With Quote
Old 02-04-2017, 08:35 PM   #3
SirDigby
Drives: 2007 yaris 3 door
you have to take the bumper off?
Old 02-04-2017, 10:02 PM   #4
Headlamp Change
Without extremely tiny hands, the easiest way to change the bulb is to physically remove the headlight assembly. This is held in place by 3 fasteners, one of which is unfortunately concealed by the bumper cover. You need to remove the push pins along the top and release the sides where bumper meets the fenders. Then the bumper can be tilted forward enough to reveal the hidden headlight fastener.
Old 02-05-2017, 12:13 AM   #5
mimelio
Drives: NONE
https://www.youtube.com/watch?v=rPpXkBBfYEU
Very easy I did it this way
mimelio is offline   Reply With Quote
Old 02-05-2017, 09:56 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
lamp bulb parking headlamp
I removed battery and airbox to replace one of the two parking/running bayonet type bulbs. Would expect same for headlamp.
Old 02-05-2017, 10:55 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
much easier by removing bumper skin
Old 02-10-2017, 11:09 PM   #8
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
+1
Old 02-11-2017, 01:18 AM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Is this a hatchie specific deal?!
On my sedan i have excellent access to my bulbs...of course now with my h1 hid projector retrofit its a little tedious but i do not have to remove a thing to gain access
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-12-2017, 06:32 PM   #10
wng-2
wng-2's Avatar
Thanks. I wasn't having a good day that day in the cold. I ended up getting the headlight assembly out enough to get the job done. I curse the designer of that......
Rich,
Berwick, Maine
Old 02-13-2017, 02:27 AM   #11
toad
toad's Avatar
Drives: street-legal go-kart
yeah, i was thinking the same thing too, but his profile says 'hatchback'. i have an 07 sedan and the bulb changes are simple. i've heard it's different on the 3-door.
i had a 3-door 08 for a while, but i don't recall ever having to change bulbs(i did lots of other things though- axle-back exhaust, lowering springs, strut tower bar).
toad is offline   Reply With Quote
headlamp change options? bechdan Cosmetic Modifications (Exterior/Interior) 4 07-20-2013 02:52 AM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-10-2011 11:51 PM
One filament in the headlamp bulb. ellenbetty General Yaris / Vitz Discussion 7 09-06-2009 01:30 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
