Old 02-11-2017, 08:49 AM   #1
rabbito
rabbito's Avatar
Piggyback ECU upgrade
had a basic timing advance ecu when i changed to E85..but i felt like its not enough..
instead of going for cams im giving shot to piggyback ecu with more controls..so i took them out and installed piggyback ecu..advance timing is set same as before, now controls fuel injection(1jz injectors) and fuel cut at 7,000rpm(factory 6,500rpm)..no, i cannot pass 7,000rpm without proper cams and after market valves/springs..
it feels strong and smooth through out the whole rpm band, i think fuel injections doing its job..20170211_160939.jpg20170211_135138.jpg
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
