Old 02-24-2017, 09:32 AM   #1
JSCIII
Drives: Yaris Hatchback 3 Door USA Ver
Yaris Steering Problem! Need help!!
Hello Folks!
It's been a while since I write here, I've been having some major issues with my '08 2 door Hatchback, I love the car and everything but pretty much. I feel like crushing it right now.
The car started pulling to the left on his own on Monday randomly, no bumps or any particular situation with it. I thought it needed an alignment but upon putting it on jacks, I found that the steering wheel is pulling to the left on its own and I can hear the EPS engine on in the back of my dashboard.
Weird thing is, there's no P/S light on or any codes, got the car to a Toyota dealer and upon plugging it on to the scanner, it stopped turning left, no actions taken by the mechanic, just plugged the car into the scanner.
A few miles later, same thing again, wheel turns left on its own, anyone has had this problem ever?? I'm desperate and really bummed, I bought this beautiful car after a car wreck with my old corolla '98 and thought this was going to be much better but turns out it didn't. Thank you folks for your help and comments in advanced!!
JSCIII is offline   Reply With Quote
Old 02-24-2017, 01:12 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Sorry to hear that. Haven't seen anything like that reported before. If it were me, I'd leave it with Toyota, or your trusted mechanic, for a few days so they could drive it a bit and try to replicate.
On Instagram
On Wheelwell
Old 02-26-2017, 11:30 AM   #3
SirDigby
Drives: 2007 yaris 3 door
yeah. dealership time. I would not take it anywhere else, unless it's a dedicated Toyota repair facility. (in Denver there is a few, like ToyTech...)
most likely a fault in the EPS controller and will need replacement. idk if there is a zeroing procedure for Toyota, I would think there is, but i'm not sure...
Old 02-26-2017, 10:29 PM   #4
Try disabling the power to the EPS. If your problem disappears there's probably issue with the steering angle sensor or load sensor.
Old 02-27-2017, 02:05 AM   #5
JSCIII
Spot-on!!! Took out the angle sensor and found a short-circuit, cleaned the component and mounted back everything, issue is gone! Thank you folks!! 👌🏼👌🏼
Old 02-27-2017, 08:11 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
Yaris electric steering assist short circuit
What caused the short circuit?
Old 02-27-2017, 09:04 AM   #7
Old 02-27-2017, 11:47 AM   #8
dogsridewith
um. electrically conductive contaminant caused the short?
Old 03-08-2017, 03:17 PM   #9
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Great, glad your fixed up.
Old 04-13-2017, 03:35 PM   #10
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Was it a C1515 code?
I've undone my calibration with a scan tool, now I need help...
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 04-13-2017, 08:11 PM   #11
link
Old 05-22-2017, 04:03 AM   #12
JSCIII
Short was caused by the wires, seems to be they're broken. Basically nothing is damaged but the cables that go from the computer to the control module need replacing.
Old 05-22-2017, 07:03 AM   #13
dogsridewith
anything to do with "spiral cable?" (which was a factory recall on my 2007 hatch)
2008, eps, hatchback, steering issue, yaris
steering problem redgreen DIY / Maintenance / Service 31 09-18-2015 08:20 PM
First post from Yaris noob... Steering wheel and double din? Ash187 Cosmetic Modifications (Exterior/Interior) 1 09-08-2013 02:19 AM
WTB Yaris electric steering column + steering ecu ayashifx55 Willing to Buy by private party 6 04-04-2013 03:41 PM
