Old 02-28-2017, 04:11 AM   #1
spookybathtub
Drives: 2007 Yaris HB
Sitting in car with engine off
I often sit in my car with the engine off, whether I'm listening to the radio, talking on the phone, etc. Is there any problem with doing this and leaving the key in the ON position for a long time? I have heard someone say that I should switch it to ACC in order to make some components last longer, but I don't quite understand that. I like ON simply because in ACC, there is an annoying beep when you open the door. And it's nice to have the clock display.
I'm installing a voltmeter so I can keep an eye on the battery.
spookybathtub is offline   Reply With Quote
Old 03-07-2017, 07:13 PM   #2
Pinchlite
Drives: 2007 yaris HB
I took out instrument cluster and physically removed buzzer,no more annoying buzz.
I also installed afetrmarket stereo(Shows time/date) and have it directly wired with toggle switch where foglight switch is.
you can directly wire the factory deck aswell.
some say without buzzer you will forget things are on that the buzzer would ordinarily warn you about.Never had a problem with all my cars over the years.
I also have my fogs hooked up direct with toggle.have never forgot to turn those off either.
ACC>Components last longer doesnt make sense.Need more info.
Pinchlite is offline   Reply With Quote
Old 03-07-2017, 08:19 PM   #3
bronsin
bronsin's Avatar
Prolly your battery and possibly ignition components will suffer, perhaps greiviously.
Old 03-07-2017, 08:24 PM   #4
All the way to on will also turn on all your stuffs, including the ECU and gas pump. Quite a power hog for nothing.
Sent from my SM-G930W8 using Tapatalk
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 09:02 PM
