#1 |
2004 echo alternator amps?
alternator seems to be giving up the ghost on my echo....battery light came on this morning...goes off at highway speeds (rpms/load)
what is the amperage of the replacement alternator? im seeing 70 80 and 90amps... thanks!
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The Denso OE alternator is 70A, if you're not running some crazy stereo system I don't really see the need to go beyond that. There is a issue with the alternators in the Yaris with corrosion forming on the voltage regulator terminals inside the regulator. Toyota issued a TSB advising replacing the alternator but you can take it apart and clean off the corrosion quite easily once you remove the alternator.
https://www.youtube.com/watch?v=kAKLeeQWCW8 New and reman alternators are quite pricey so I'd suggest the repair method or a trip to a salvage yard. |
#3 |
90A was actually cheaper than 70 or 80 amp
bought a rebuilt model with a lifetime warranty for $120. installed it this afternoon.. need to take the car for a drive to charge it up
| 2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . | mpcv2000 | Canada | 73 | 05-20-2021 07:14 AM |
| 2004 Canadian Echo Hatchback Fog light Kit ( OEM Style ) | mpcv2000 | Cosmetic Modifications (Exterior/Interior) | 26 | 04-06-2017 12:25 PM |
| Toyota Echo 2004 | xoretrofuturist | Australia | 0 | 07-03-2012 09:18 PM |
| [Q]Yaris Front Lip + Echo 2004 HB? | NotMad | Cosmetic Modifications (Exterior/Interior) | 0 | 06-28-2012 03:31 AM |
