Old 03-09-2017, 10:01 PM   #1
nate0
Drives: 2013 hatchback Yaris
Not Starting 2013 Yaris Hatchback
Hello everyone, I just had this 2013 Hatchback Yaris for about 3weeks now with 165km no accidents. It was running good until yesterday night, on my way back from work I filled up then drove home for like 20min. An hour later, someone else in the family use it to go to grocery. It all see fine.
In the morning I tried to start it. It would start for like a second or two and stop. It would do it again if I tries to crank 2-3 times. Then it would just crank after that, will not run momentarily and die.
I tried to use the quick start spray and it would start momentarily and die.
Is this a fuel pump problem or relay?
I am trying to find the relay to swap out but could not locate it.
Can someone tell me the name I am suppose to look for please?
nate0 is offline   Reply With Quote
Old 03-09-2017, 10:03 PM   #2
nate0
Old 03-09-2017, 10:04 PM   #3
nate0
Old 03-09-2017, 10:05 PM   #4
nate0
Old 03-09-2017, 10:06 PM   #5
nate0
Old 03-09-2017, 10:06 PM   #6
nate0
Old 03-09-2017, 10:10 PM   #7
nate0
When I turn the key to ON I don't hear the fuel pump. No sound from the back.
I was reading the other threads for 07 yaris they would jump the pins to manual activate the fuel.
Anyway I can do this on the 2013? Thanks
Old 03-10-2017, 11:09 AM   #8
The pump will only turn on after cranking the engine. But it's much simpler to just check for power at the pump with a volt meter. Just remover the rear seat bottom and pull open the cover. You can use cheap sewing needles as pin probes.
Old 03-10-2017, 01:30 PM   #9
nate0
Alright thanks for the good advice. I will take off the back seat sometime today and report back.
Old 03-10-2017, 02:19 PM   #10
How low was your fuel tank before you filled up?
Old 03-10-2017, 05:12 PM   #11
nate0
Just a little under 1/4 left of a tank.
It's snowing outside today so I didn't took the back seat out yet.
But I did put in new Bosch plugs since it need a tuneup away. Plugs look old but clean no grease or anything. It's definitely not the battery as I tried to start it a few times normally(without quick start spray) and it start and stop.
So cranked, start for like a second and stop. Depress the gas pedal does not do anything.
Old 03-10-2017, 05:15 PM   #12
Add a gallon of gas just to be 100% sure it isn't out of gas and the gauge is simply wrong.
Old 03-10-2017, 05:26 PM   #13
If is cranks, catches and then died withinntje next 3 seconds that is what the immobliser does when it reads an incorrect key. Something to check just to be sure
Old 03-10-2017, 05:36 PM   #14
nate0
I hook up the innova scantool. I forgot I had this.
It does show Engine Immobiliser System Malfunction and another Startability Malfunction.
For the gas, what I mean was I filled up when it was just below the 1/4. So it full and its show that on gauge.
What can I do if it reads the key as incorrect?
Old 03-10-2017, 05:51 PM   #15
nate0
Old 03-10-2017, 06:03 PM   #16
Go to the dealership and get them to re program it. Or buy a techstream tool of eBay for cheap and do it yourself.
Although I'm curious As to how it suddenly stopped reading the key? What did the person do who drove your car? Could be a key issue or could be an immobilizer issue
Old 03-10-2017, 06:08 PM   #17
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Try another key for the car. That's very odd for it to do that. Hopefully you have more than one?
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 03-10-2017, 07:44 PM   #18
nate0
Only have the one key :(
Dealership only option then for now as I kinda need the car. As ebay can take a while.
starting problem on 2008 d4d yaris georgeg General Yaris / Vitz Discussion 15 06-13-2016 10:26 AM
Yaris 2013 engine braking problem? pikador DIY / Maintenance / Service 5 01-05-2014 04:12 AM
2014 Mazda 3 Kal-El Off-topic / Other Cars / Everything else Discussions 32 11-08-2013 12:51 PM
